shop put 5 quarts oil in my car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Jun 9, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    i just got oil change, shop put in 5 quarts instead 4.5 quarts, is it ok or should I tell them to take out 1/2 quart? will mpg going to lose some?
    thanks all
    V/r
    Khoi Nguyen
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Use the dipstick, check the level. If it is above the maximum fill line (second dot), you need to drain some. Simple as that.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I only put 3.75 quarts in mine so I would be having them take a bit more out.
  4. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    I checked, just a little over the second dot, should it ok?
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,738
    Bay Area
    I would drain it out until its either on the 2nd dot or between the min and max dot, it can cause problems for your vehicle if its overfilled.
  6. bisco
    51,895
    i've never seen an mpg problem with upto 1/8" over top dot.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The top dot is the max fill line. If it is over max fill, it is overfilled. Easy to just suck some up the dipstick with $1 worth of aquarium tubing.
  8. bisco
    51,895
    i agree, but i never saw any short or long term ramifications.
