Dangling Piece Under Prius (with pictures)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MNTech, Jun 10, 2013.
  1. MNTech
    MNTech Junior Member
    24
    Ever since I've had my prius I noticed a dangling hose? wire? Haven't thought much about it since it doesn't effect performance, but what exactly is this and how do I fix it? 20130610_160847.jpg 20130610_160816.jpg
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    Is that an emergency brake cable/housing for the left-rear wheel?
  3. El Dobro
    El Dobro A Member
    7,093
    3,271
    That would be my guess. Looks like a retaining clip that holds it to an anchor is missing.
  4. MNTech
    24
    Thanks for the responses. Not going to worry about it.
  5. El Dobro
    El Dobro A Member
    7,093
    3,271
    You may not want it to snag on something.
  6. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    But at least you should try to attach the dropping down(dangling) portion to the under chases to prevent accident as if you drive over somewhere with object pointing out will catch the dangling part. Either the cable got broken or even damage the rear brake. Don't leave it. Fix it. Use glue or some way to make it attach to the under chases. Or go to a garage to fix which is a easy job for them and should not spend much.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Next time you park on a hill, you may regret not getting it fixed!
    You really need to fix, not blow it off, this!
    Really!
  8. MNTech
    24
    I'll get it adjusted the way it was originally. Was checking here to make sure it was not an electrical wire or fuel hose to be concerned about.
  9. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Yes fix and drive.
