Roof Rack Questions 2012 Prius with Solar Package
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Squeakymk, Jun 12, 2013.
  1. Squeakymk
    Squeakymk Junior Member
    Fairfax, VA
    I found a complete Thule roof rack system with fit kit for kayak on Craigslist. I have a 2012 Prius III with solar package and this system is from a 2009. Is there a difference in the two systems? Will that work on my car?
  2. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    I'm not too sure I'd put a roof rack on a solar roof. A gen 2 Prius has a different body.
    My $0.02
  3. Squeakymk
    Fairfax, VA
    Oh, it's happening...just need to know if this particular one is doable.
  4. john1701a
    john1701a Prius Guru
    12,819
    5,304
    58
    I transferred my Yakima from a 2004 to a 2010 solar...
    It worked fine, though I did have to change the clips.
    Toddwilks likes this.
  5. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    I have a thule roof rack fitted to the solar panel roof. Only thing is that you can't open the sunroof as the roof racks will interfere with any movement of the glass panel.
  6. SmellyTofu
    251
    29
    Sydney
  7. Tribeca487
    Tribeca487 New Member
    Alexandria, VA
    Are you able to open the solar roof while the rack is mounted? Thanks!
  8. Tribeca487
    Alexandria, VA
    Did you ever succeed in installing rack on solar roof and if so does the solar actually open with the rack installed? Thank you!
  9. maximgr
    maximgr Junior Member
    Montréal, QC, Canada
    Premium w/ Solar Cells
    Would love an answer to that too!
