Dash removal doc (process)
Discussion in 'Gen 3 Prius Audio and Electronics' started by rrolff, Sep 28, 2009.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Here's the doc for removing the front dash... If your doing this to add GPS, you may consider what I did - just put the GPS antenna under the tweeter cover on the drivers side. Simple to pull the wire (from the bottom), and the location seems perfect for signal...
    Ashim123, Sfcyclist, lumpy95 and 15 others like this.
  2. jbaflyer
    jbaflyer Junior Member
    Great Post, Thanks.
  3. PixelRogue
    483
    86
    US
    Thank you.. perfect.
  4. Ajwatuc
    Ajwatuc Junior Member
    75
    Awesome this should be a sticky!
  5. Marty Lee
    Marty Lee Junior Member
    States
    I downloaded these PDFs to my Android device. this device can open the other PDFs fine. on this one it says cannot open file. is there a special code or a way to do this?
  6. PixelRogue
    483
    86
    US
    Dash dis Prius:
    Image 2 - is that illustration stating to place electrical tape along all the seems, or to expect double sided tape under the seems? Videos of the steps handy?
