Phone contacts unstable
Discussion in 'Gen 3 Prius Audio and Electronics' started by RockerC, Jun 13, 2013.
  1. RockerC
    RockerC Junior Member
    39
    I have hooked up my iphone 4 to the in car system no problem, and the contacts have been transferred. However, when I leave the car and come back, the phone is recognised, but sometimes not the contacts. The display will show the phone connected but with nothing in the contact list. recent calls show, but not the list of contacts. If I then turn off the bluetooth on the phone and then back on, it will reload. Any clue if this is 'normal' or is there something I am not doing correctly?
  2. MBRGuru
    MBRGuru Member
    255
    26
    Is this when you're driving, or always when parked? They'll go away when you're driving and you'll only get access to the recent calls. If recent calls transfer, then the PBAP transfer is working at least somewhat.
  3. RockerC
    39
    If I take the time to reload the contacts by turning the Bluetooth off on the phone and then reconnecting, the contacts will load and then stay while driving, until I stop again. Then I have to go thru the process once more if they become disconnected after stopping etc. This is inconvenient if I am running errands with multiple stops, while still wanting to make calls while underway.
  4. labradorPrius
    labradorPrius Junior Member
    Did you every solve this issue? Does it still happen to you? I am having the same issue with my contacts. It was stable for weeks. it just started two days ago.
  5. labradorPrius
    I have given up.
    iPhone ?
