Prius pulling an RV? What do you pull !!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by engerysaver, Jun 16, 2013.
  1. engerysaver
    engerysaver Real Senior Member
    426
    132
    Tyler, Texas ; USA
    And they said it couldn't be done?
    I'm not that good uploading things!! This is my first thread that I started.
    I have two 2011 Prius. I took the silver one away from my wife; so I had to buy her a gold one. I took the silver one and put Hidden Hitch # 60263, with wiring for brakes on it (about $205.00 ). I then had to beef up the rear end by adding Firestone air springs # F-4136 ($85.00 a pair), with 35 to 40 psi added . Had to buy a brake controller at Auto Zone (for about $105). My trailer is a 16 ' Midget RV, GVWR at 1700 lbs, with GAWR at 2200 lbs. I'm about at 1900 lbs in trailer.My MPG full tank to full tank was 25.5 MPG, pulling the trailer. But I did make a 20 mile trip without the trailer; which would drop my MPG to about 23 to 23.5 ? range, after a total round trip of about 210 miles, with about 800 lbs in the Prius. Now that is a load? The Prius worked very hard on long hills. I also have a 1500 inverter hooked up to the battery.:) ...If you like this info... Press Like. ;)
    ...What do you pull with your Prius?​
    #1 engerysaver, Jun 16, 2013
  2. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi engerysaver
    where can I get Firestone air springs # F-4136, I have 2010 prius, do you think it will fit my prius? I plan to hook up my Stowaway cargo carrier alot, I need to raise the back of my prius about 3 inches, may I see some pic of Firestone air springs # F-4136 installed in your prius please.
    V/r
    Khoi Nguyen
  3. engerysaver
    426
    132
    Tyler, Texas ; USA
    E-TRAILER.COM has them for $ 99.67 as of June 15, 2013...Mine had 50 lbs in them, which is about 10 lbs too much. It takes just a little air to pump them up!! I'm going to say 2 1/2" to 3 " max. It will fit 2010 Prius.
  4. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    thanks so much for info, when I go to E-trailer.com, it state that for 2012, so it ok right? if this work, I really needed, after the round trip from San diego to Houston and back I wish I have known this.
    engerysaver likes this.
  5. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi Energysaver
    just want to making sure, I saw F4106 not F4136 like you stated, which one you had?
    V/r
    Khoi nguyen
  6. engerysaver
    426
    132
    Tyler, Texas ; USA
    F-4136
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    can you send me a link? I could not find that in E-trailer.com
    Thanks
    Khoi nguyen
  8. Former Member 68813
    3,524
    983
    US
    One word:
    WOW!
    I'm OK with pushing the envelope and I used to pull my boat (3000+ lbs loaded) with subaru (but with trailer brakes, mind you), but this is a bit extreme.
    Reminds me this:
    Flyin2Low, sabasc3, Jeff N and 2 others like this.
  9. engerysaver
    426
    132
    Tyler, Texas ; USA
    Try " etrailer.com ", without " - ", in it. Small caps.
  10. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    engerysaver
    Thanks so much, I will order one today, by the way I look at, it is not to do it by myself, did you do it by yourself or you let the shop do it for you? how hard to do it? how long does it take to completed? do you think better to let the shop do it for safety?
    V/r
    Khoi nguyen
  11. engerysaver
    426
    132
    Tyler, Texas ; USA
    It cost me about $ 100.00+ to let shop do it.... all the work is under the car.
  12. bisco
    51,840
    will this stress out the hsd?
  13. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    engerysaver
    Thanks so much, I will let the shop do it for me for a piece of mind.
    Bisco
    maybe pull the trailer, which I will not do that like Engerysave, but I do carry Stoway box which is 16 cubic feet and it really put the back the car LOW, that why I need it, by the way, why not stress out HSD? saving gas and testing the new thing :)
    V/r
    Khoi nguyen
  14. engerysaver
    426
    132
    Tyler, Texas ; USA
    HSD might be stress on long hills, high speeds..... time will tell.....avg driving now 48 to 52 MPG with about 34,100 miles on it; which is no change on my MPG before my test. If you like any of my info, press like !!
    douglasjre and AllenZ like this.
  15. engerysaver
    426
    132
    Tyler, Texas ; USA
    I think the key is to not put too much stress on HSD at one time. Long hill ....take a running start, drive slower or just take another route with less hills. HSD is more tougher than what people think.
  16. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
  17. engerysaver
    426
    132
    Tyler, Texas ; USA
    I know their are more Prius owners pulling trailers; RV's; flat trailers; campers; ect.......... Lets here from you !!
  18. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    yes please, let hear from all of prius puller :)
  19. andreyco
    andreyco Member
    91
    27
    This sounds like a great way to destroy your car. Keep us updated :cool:
    Toyota goes out of their way to recommend that you don't even use a bike carrier with your car, and here we are, towing 1600lb
    Flyin2Low and orenji like this.
  20. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    sabasc3 and KK6PD like this.
