Am i overdue for brake fluid & power steering fluid @ 142,000??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by deunan, Jun 15, 2013.
  1. deunan
    deunan Junior Member
    27
    PDX
    i got 2010 prius with 142,000 miles,
    dealer never said anything about brake and power steer fluids service.
    did 2 transaxle fluid already and both coolant.
    Am i overdue or ok until 200k?
    thanks
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    The steering's electric, so there's no fluid. As for a brake fluid flush, you may want to leave that to the dealer. Oh, and at that mileage, I would have the brake fluid flushed.
    TsKarma, JMD and frodoz737 like this.
  3. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Second that
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I will change every drop of your steering fluid right now.... Done. I would wait till 200k to flush that brakes. But it wont hurt anything if you get it done now.
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Brake fluid's usually done as a function of calendar years. The German cars recommend every 2 years but most of the rest of the industry doesn't worry about it short of 10 or so.
    If you can manage to keep things clean, you could change out the brake fluid in the reservoir alone with a turkey baster every few months. The brake fluid does slowly infiltrate the system and this would be a cheap, simple way to renew things gradually.
  7. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    css,
    I disagree with your procedure. The new fluid would not get very far and only travels as the pads wear. It might get through the master cylinder, but with the accumulator, the electric pump and ABS valves all in the system,, it will never make its way to the calipers. The calipers are where the fluid meets the heat!
    You really need to give the system a proper fluid change if you are going to do this job.
    WADR, your method is just a feel good thing.
  8. Mendel Leisk
    41,784
    Honda say's every 3 years, independent of mileage. Toyota doesn't seem to mention it.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I agree that a full fluid change is preferable but disagree that the fluid doesn't mix.
    In a previous life I worked for a brake system manufacturer. One of our OEM customers used their own brake fluid formulation that proved corrosive to their rear wheel wheel cylinders. They ended up with a problem because the iron oxide would migrate to the master cylinder reservoir and stick to the ring magnet in the fluid level float, binding it up.
    If the fluid weren't mixing you wouldn't see the gradual darkening of the fluid with time.
    xs650 likes this.
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    Lexus recommends brake fluid changes IIRC, every two years.
  11. eliotb
    eliotb Junior Member
    68
    Northern Virginia
    Ditto on two years. I bleed my Jag brakes every two years. Brake fluid is hygroscopic (it absorbs water) and over time you might find it boiling away in a panic stop as the caliper absorbs the heat load off the discs. If the fluid is dark and it's been two years, either bleed it yourself or have it bled by a pro and replaced with new.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Bill Norton likes this.
