Warning...Why you might not want a remote starter, if you store your car in an attached garage.
Discussion in 'Fred's House of Pancakes' started by Mike500, Jun 18, 2013.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    It just happened, here, locally.
    A couple was found dead in their beds with high levels of carbon monoxide in their home. Also, they didn't have a carbon monoxide detector.
    One of them had accidentally started their car in an enclosed garage. The car was found with the tank "out of gas."
    At the very lease, if you have one of these, get carbon monoxide detectors, even if you don't have a combustion furnace.
    Trebuchet and WE0H like this.
  2. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Not really a problem with a Prius as the engine won't run non stop unless the temperature is below freezing.
    If your attached garage is blow 50 F something isn't right to begin with and sure if you use heat often you need a carbon monoxide detector.
    In my garage the prius would sit off the majority of the time and might run out of gas in a week or so from a full tank, at least 2 days from low tank.
    Besides the Prius doesn't spew out enough CO to kill someone in my house, too many cu ft vs one very low emissions gas engine.
    All in all I'd say this thread is about useless to anyone with a car made after 2005.
  3. Mike500
    2,593
    767
    Most of us, here, I don't believe want to be Guinea pigs or test subjects.
    I guess some people don't need to wear motorcycle helmets and seatbelts, either.
    I knew a guy, who did "organ recovery" at an ER once.
    He said that his work most often involved young motorcycle riders who did not wear a helmet.
    It does, however, mean it's a Godsend to those who need organ donors.
    Kit Shah likes this.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    No report on this recent tragedy I can find reports that it was a Prius.
    In fact the only report I can find seems to suggest that authorities think the couple drove the vehicle into the basement garage and then left the vehicle running. No mention of it being a Prius and/or having remote start.
    There have been tragedies in the past with push button start.
    Toyota sued in carbon monoxide tragedy | PriusChat
  5. Rupert B Puppenstein
    Rupert B Puppenstein Active Member
    261
    126
    North Carolina
    I don't understand how someone can accidentally start their car with the remote starter? Do many people sleep with keys in their pocket? I do agree that everyone should have a carbon monoxide detector in their home. It isn't just the car that is an issue. If you have anything that uses natural gas, it can do the same thing. There may not be many stories about the Prius killing anyone from this phenomenon, but there are far too many people who die because of carbon monoxide poisoning.
  6. Mike500
    2,593
    767
  7. Mike500
    2,593
    767
    It's pretty easy to do with the SmartKey system. I don't have the remote start option, but if you keep the key in your pocket with keys or other things, it could happen. It's happened to me several times with the "panic button."
  8. The Electric Me
    9,083
    5,801
    Yes, but that report say's "Keyless Ignition" not "Remote Start".
    Never mind, seems they are not sure whether the vehicle was left running OR accidently started with a remote start.
    Can anyone explain this statement from last paragraph of the above article:
    " The National Highway Traffic Safety Administration has proposed a rule to standardize the length of time required to use a keyless control to a half-second, and it would require that engines or propulsion systems shut down in one full second."
    What? I'm not really clear on how those applied standards would of avoided this type of tragedy. If the couple either left the vehicle running by mistake, or accidentally started it with the remote start I hardly think a 1/2 a second to start and/or a full second to shut down would of made a difference.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I crouched down to inflate a tire in my driveway only to hear the air conditioning start up in my Prius once.
  10. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Remote starters are usually set to turn off the vehicle after 10 minutes. Also, only a total of 20 mins or so of activation before one has to physically get in the car and start it before it will remote start again. The total minutes I have may not be exact but they are around the times as mentioned in the factory remote start manual...
    SCH-R530M ? 2
    WE0H likes this.
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    A properly constructed attached, or interior garage will have NO way for the CO fumes to enter into the house. It's a poorly constructed house where garage air can mix with house air. Also bad builders, and poorly written codes come into play!
    A stupid way to die....detectors are so cheap....how much is that life worth?
  12. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    my challenger will only run for 10 minutes if remotely started
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    To prevent tragedies like this, remote starters automatically turn off after a few minutes. Sounds like bad garage ventilation and neglect to turn off the car is the reason for this couple's death.
  14. 13PV
    13PV Junior Member
    82
    2013 Prius v wagon
    we have the factory remote start. it takes a sequence of button pressing to enable remote start. now i'm not saying it's impossible, but i bet i'd win mega millions before i could get my car to randomly start by having other keys in my pocket.
    also, the hybrid "starts" for 10 minutes, but the engine runs intermittently.
    WE0H likes this.
  15. dhanson865
    851
    188
    TN, USA
    Toyota Avalon with a V6 of 3.5L is nothing and I mean nothing like the emissions of a prius with a 1.5L or 1.8L 4 cyl engine that auto shuts off when the traction battery has enough bars and the car is not moving.
    Yes a traditional ICE vehicle like the Avalon can kill you with emissions, NO a modern car like a Prius can NOT kill you in the same way.
  16. dhanson865
    851
    188
    TN, USA
    My house has a 2 car garage below the bedrooms in a split foyer layout. The central HVAC uses plenum return and I highly doubt the garage to living space interface is air tight.
    Then again between the garage and living space there is something on the order of 25,000 cu ft of airspace and I tend to leave the fan on continuous to filter allergens so how much could the concentration be with one vehicle vs that much airspace?
    I'm sure if I left a older V6 running with a full tank of gas it could fill the space but a modern SULEV like the Prius isn't going to fill that space with CO.
    see United States emission standards - Wikipedia, the free encyclopedia
  17. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    Not a problem with an American made Ford F150 running on CNG.
  18. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Only a start button push of more than 1/2 sec and less than a full second would start the car. The idea being a short jab or sitting on the fob would rarely be in this time window.
    The Electric Me likes this.
  19. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I really don't like keyless ignition, especially for me. This is just a couple of deaths, but deaths none the less. The 2004-2009 Prius had it right. The 2010+ Prius does not. I'm stuck with 50 years of irreversible car programming. If the key is in my pocket and the engine is not running, then my subconscious programming tells me the car is off. I've been working on changing it, but 50 years of (formerly) correct operation is not changed by one car in a couple of years.
    This is a case of convenience becoming deadly.
  20. dhanson865
    851
    188
    TN, USA
    Old dirty engines can be very dangerous, I'm not worried about keyless ignition but I would be worried about an old engine.
