Prius v level?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by vsuirpsteve, Jun 19, 2013.
  1. vsuirpsteve
    vsuirpsteve Junior Member
    32
    Ok...I might be drinking way to many margaritas with summer now upon us in Florida but I would like to know if others with the v have this same leveling issue. I am one of those guys that is sensitive to things that are not level and sure enough when measuring the Prius I see that the left side is lower than the right.
    Can any of you take the same measurement points from the ground to the top of the reflector and see if I should lay off the margaritas or what could be causing this?
  2. mikefocke
    4,034
    1,828
    Sanford, NC
    24.5" on both sides. v 3
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    24" exactly on both sides on my v5
  4. vsuirpsteve
    32
    Dang! Thanks guys...Any reason why this could be?
  5. Mike500
    Mike500 Senior Member
    2,593
    767
    Do you drive alone? The springs might wear and sag more on the driver's side.
    It happens to me.
  6. vsuirpsteve
    32
    :( Ok I get it...hitting the gym. ;-)
    Mike500 likes this.
  7. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Is it safe to assume that you've checked your tire pressures?
  8. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Its probably worth checking out. The best way might be to have the dealer put it on a ramp rack and measure the height of each spring. No way should a spring be sagging after only a year or two.
  9. vsuirpsteve
    32
    Yea...checked tire pressures all even...that would suck if the springs are sucking this soon.
  10. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    It would only take one bad spring. It does happen, though rarely. There's other things in the suspension that could do it too.
  11. vsuirpsteve
    32
    Is that sort of stuff under warranty?
  12. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I'd assume the suspension is under the 36/36 warranty. A spring isn't a big deal to replace.
