2014 Honda Accord Hybrid Gets 49 MPG in City Driving
Discussion in 'Honda/Acura Hybrids and EVs' started by cycledrum, Jun 20, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    "TORRANCE, California — The 2014 Honda Accord Hybrid gets an estimated 49 mpg in city driving, according to American Honda Motor Co. The release of the fuel economy estimate signals a fight between the Honda Accord Hybrid and the Toyota Camry Hybrid.
    The 2013 Toyota Camry Hybrid, the Accord Hybrid's chief rival, returns 43 mpg in city driving and 39 mpg on the highway, according to the EPA. Honda estimates that the 2014 Accord Hybrid will return 45 mpg on the highway."
    2014 Honda Accord Hybrid Gets 49 MPG in City Driving | Edmunds.com
    Intersting little oval port in lower grill. Some type of launcher? :)
    I could live with this interior in tan or light gray
    Whatchya think?
  2. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    Oh wow. That's actually kind of nice.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Don't understand why this was moved to Honda hybrids section while many other mfrs cars are announced in 'Prius, Hybrids, EVs, Alt vehicles' section. Bad title?
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    'because it's a Honda hybrid?
  5. bisco
    52,390
    i got 60 in the hycam, perhaps toyota will send out a press release.;)
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  7. bisco
    52,390
    you can run, but you can't hide.:p
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    What? Who?
    Interesting to find out the Honda 2-motor system is totally different than T, F, H, K, but may be something like Fisker's architecture. Let's hope it's good if you believe there's room to expand the pie.
  9. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Can't believe they copied the awful 4 spoke steering wheel design of the Prius.
  10. bisco
    52,390
    i absolutely believe in expanding the pie, but i would love to see some real advancements in hybrid technology, not just we have one too mentality. i'm hoping honda has something exciting here, but if it winds up being 40 mpg and honda afficionado's dig it, that's not a bad thing.
  11. Trollbait
    12,684
    And yet the next gen Rav4 thread in the hybrid news section was never moved to other cars.:rolleyes:
    Let's hope the real world lives up to the hype.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It looks promising but I have a concern.
    The way it works is in contrast. It is either series hybrid (gas -> generator -> motor) or direct gas engine drive (single speed). It doesn't seem to do any blending of the two to get infinitely variable torque output, like HSD.
    Low to mid speed is covered by the electric motor (power from the battery, gas generator, or both). High speed is done with a single gear gas engine.
    The setup may perform well for EPA test cycle because the controls to switch between the two modes can be optimized. The question is the fuel economy in the real-world driving, especially aggressive driving or the type that forces the series mode. It could be a hypermiler dream car due to the direct mechanical drive mode. I am concern that mode will be of limited use for "normal" drivers.
  13. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Look forward to seeing the real world mpg.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ok, so HSD blends in electric power through PST to keep gas engine in its most efficient range With the Honda system, the motor(s) have no way to keep gas engine in its most efficient speed range?
  15. james cook
    james cook Member
    145
    36
    Louisiana
    2025 Prius
    Cool, too bad the IMA is basically a regular gas powered car with all the maintenance and moving parts.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, that's my understanding from reading how it works.
    Series mode will take conversion loss. Note, all the power from the gas engine will need to go through conversion. In HSD, it is a small percentage the way PSD is setup to split.
    The direct clutch engine drive may be great for cruising at constant speed. Passing or acceleration that need to "downshift" may end up in series mode (taking efficiency hit).
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    hard to see high 40s combined from the 2-motor drive. I'm thinking Honda could not design similar to HSD because of the patents (which run out this year?). Ford could because of cross licensing.
    Little shift of topic, but the HSD transaxle components don't appear to be so large or complicated (aside from stators, housing, inverter) compared to an automatic transmission. See 22 min and later.
    3rd Generation Toyota Hybrid (eCVT) Transaxles - YouTube
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yup, eCVT is mechanically very simple. No clutches and nothing mechanical to shift. The only thing it shifts is the propulsion motor/engine -- continuous variably.
    Gen3 eCVT is more powerful yet smaller and lighter than Gen2 (see below). It includes both electric motors. The only thing missing is the gas engine, inverter and battery that's not considered part of "transmission". To certain degree, I don't think we should include the electric motors as "transmission" in traditional sense. Which is why I prefer to call it hybrid transaxle.
    It does more than the job of a tranaxle because it plays the roles of starter and alternator as well.
    MG1 for Gen2 (left) and Gen3:
    MG2 for Gen2 (left) and Gen3:
    Power Split Device for Gen2 (left) and Gen3 (includes MG2 speed reduction unit):
    Entire hybrid transaxle Gen2 (left) and Gen3:
    cycledrum and Sergiospl like this.
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, absolutely. You don't want the gas engine rpm locked into the wheel speed. That lack of flexibility would restrict the ideal use of the gas engine at optimal BSFC.
    The highest efficiency can be obtained by adjusting rpm or torque (see below -- darker area is 220 g/kwh) to get the needed power. Locking the wheel speed would only allow the torque adjustment to get to the lowest BSFC (less gram of gas to make the same power). So that limits possibilities since it can't adjust engine rpm.
    Adjusting the torque to assist ICE could be limited (not as flexible as HSD) because, the traction motor will get the power from the HV battery. If the battery is low, generator will need to run. When that happens, it will be forced into series mode. That's because gas engine power cannot be split into both mechanical and electrical path at the same time. It is the "either or" situation. You don't have the persistent electricity availability made possible by the powersplit hybrids like HSD and Ford hybrids.
    cycledrum likes this.
  20. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Interesting. No synergy, just collaboration. It seems this new 2- motor is like an IMA drive with another motor in the sandwich (traction) and a clutch for ICE to sidestep it.
    Honda seems very confident it will get high 40's MPG ratings, beating Camry Hybrid in EPA cycles. It could end up worse than Camry / Fusion. Fusion doing well with 41 on fuelly over 600k miles.
    I have found no reviews of the Accord plugin even though it's been out for 5 months. Seen no data for MPGs.
