What gas does Costco sell?
Discussion in 'Gen 3 Prius Fuel Economy' started by PriusRos, Jun 23, 2013.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Does anybody know which oil company Costco gets their gasoline from?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    In most areas it will be the cheapest local distributor, ie: generic gas.
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I think each Costco buys from local distributors, the same for all other brands. The difference is the type and amount of additives each brand uses. I can't remember where I saw a write up about their gas, but in it Costco stated they use 2x the amount required for additives in their gas.
  4. PriusRos
    1,973
    218
    Rockville, MD
  5. calirider
    calirider ECOmobile
    105
    33
    California Central Valley
    I have heard that with everyone running E10 it naturally has all the cleaning agents your motor and injectors need.
  6. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I believe that is incorrect. In particular the auto manufacturers feel a fairly high dose of detergent additive is needed to prevent gunk build-up on fuel injectors, etc. EPA requires a lesser dose than the auto manufacturers like.
    Some other additives are certainly impacted by ethanol, for example de-icing additives to prevent fuel line freeze ups would probably not be needed as much anymore.
  7. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    My MPG is down with Costco or Sams gas compared to name brands
  8. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Mine is consistently better with Costco gas.
    ChipL likes this.
