Problem Solved Charging Cord
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Valencia Orange, Jun 20, 2013.
  1. Valencia Orange
    192
    Valencia, CA
    2013 Prius Plug-in
    For the last two weeks I noticed the car charger was extremely heavy and pulling on the plug when it was plugged in.
    Today I went to the Home Depot and tried to find a solution to my problem. I looked and bought 2 L brackets and thought I would mount them and just lay the charger on it. When I got home, I realized this will work, but if I accidentally pulled the cord to hard, the charger would fall off the brackets.
    I then noticed there was a hole in the charger. I went to my accesory drawer and noticed I had a hook. I decided to bend the hook, wrap it with some black tape to prevent scratching the charger, an anchored it to the wall.
    I now can hang my charger, and if I want to take it when I go on a drive remove it from the wall. Total Cost $0
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    Yep, that's why Toyota put that in the owner's manual. :D
    markabele likes this.
  3. bisco
    51,851
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I keep a wire wrap handy for. taking the load off the brick whenever possible.
  5. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
