2006 Prius High Voltage Battery
Discussion in 'Gen 2 Prius Main Forum' started by jkjjkhj, Jun 23, 2013.
  1. jkjjkhj
    jkjjkhj New Member
    I am a new 2006 Prius owner with 1110,000 miles. Trying to learn as much as I can about the vehicle. It seems to me that that the High Voltage charge according to the monitor is fluctuating greatly over the course of one trip around town. It goes from 6 bars to 2 bars to 7 bars back down to 5 bars by the end of the trip. Is this normal or do I need to worry about the battery life? Thanks for any help!
  2. Patrick Wong
    18,210
    6,514
    Especially in hot summer weather where the AC compressor is running (and therefore putting a load on the traction battery), it would be normal for the traction battery SOC to move around as you described.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    If you find it's mostly dropping to 2 bars soon after cold starts then try letting it warm for about 50 second before taking off. This will fix the problem and is the kindest thing you can do for your battery.
    jefe likes this.
  4. jkjjkhj
    jkjjkhj New Member
    Thanks for the insight!
  5. jkjjkhj
    jkjjkhj New Member
    I will certainly try this! Thanks!
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yup fluctuations are normal.
    The easiest test is if you are doing around town driving every time you accelerate it goes to 1 or 2 bars and every time you stop it goes to completely full green. If it does that, your battery is on its last legs. The bars might (most probably) drop when accelerating and go up when braking but it should not swing full charge.
  7. jkjjkhj
    jkjjkhj New Member
    The bars are not doing that. The fluctuations are not that drastic. They drop when we accelerate and gradually work their way up during driving. So I am hopeful that the battery is still working well! Thanks for the information. I really appreciate it.
  8. jefe
    jefe Member
    169
    Cary, NC
    Things I noticed just before my battery tanked:
    • Bars would fluctuate from pink to green back to pink in a matter of a few minutes
    • Gas engine would occasionally have a short jolt of powerlessness in the morning
    • battery fan ran a lot
  9. jkjjkhj
    jkjjkhj New Member
    Thanks for that info. I will keep my eye on the battery fan and the powerlessness. So far the bars are not changing that rapidly. By the way, my vehicle has 111,000 miles on it. Had a typo in my original post...hopefully everyone caught that. Thanks again!
  10. jefe
    jefe Member
    169
    Cary, NC
    IF your battery were to die, and I don't think it sounds like it is, you are currently within that threshold that Toyota seems to be helping out with a replacement. I think I have seen it up to 112K where someone calls customer center and Toyota agreed to pay for half of the replacement. Keep that in mind, just in case.
    Mine was at 140K, so no help for me.
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Jeff,
    In reference to "a matter of a few minutes", could you please give a actual number? Also, did it seem to make any difference depending on how much load you running at the time ie: A/C and fan running etc.?
    Ron
  12. jefe
    jefe Member
    169
    Cary, NC
    I wish that I could give better specifics. Prior to it failing, I didn't pay too much attention to SOC. The first clue I noticed was the gas engine loss of power. This usually happened first thing in the morning. I would leave the driveway, hit the pedal and there would be a sudden sharp drop in power, followed by a gradual uptick.
    I wish I did more specific tests to see how long my HV was holding a charge. Once the triangle came, it was up and down like crazy.
    With P0A80 code, it seemed to continue to run fairly normal, though it relied much more on the gas engine. If I had to guess, I would say that it only took a matter of 2 minutes of normal (for me) driving for the battery to drop from 7 to 2. When I started getting cell specific codes (P3017) that's when I noticed my Prius would go into limp mode. Then I would pull over, let it cool for a minute, and it would start back up and run fine.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Remember that after the vehicle just starts it tries to warm up the engine without using it for motive power. Even a healthy pack will experience lower power and slight jerkiness when going from puttering acceleration to high power acceleration, like mashing the pedal. When the battery has almost no capacity this will be exaggerated. The minute or two will be the warmup period and vary based on temperature.
  14. dorunron
    3,318
    1,105
    Houston, TX
    Thanks Jeff and 2K1 for the replies and the info.
    I am under the impression based on what other's have written that it seems that the charge swing is just in a couple of minutes (2 or 3). As 2K1 stated, when the Prius is in "Stage 1", the system uses the traction battery the most which at times will pull down the SOC if it is not close to 6 bars. I do believe it is normal for the ICE to seem to have less power when the traction battery SOC is low (pink - 1 or 2 bars). I believe it is due to the fact that the system is actually pushing more power towards the traction battery than MG2 hence the feeling of the ICE having less power.
    So far, I have yet to hear the fan running fast but there have been times when I have run the pack down. That seems to happen to me if I am running the A/C a lot (high ambient temps) while the Prius is parked. I have timed it several times. It seems to be consistent and it averages about 15 minutes between cycles if I am not moving and the Prius is parked in direct sunlight with a ambient temp of 92 or higher. If I turn the air off, I then note it takes about 23 to 25 minutes before the ICE cycles on.
    Ron
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    From everything you have said, it appears your battery is healthy and happy with many tens of thousands of miles ahead of it.
    dorunron likes this.
  16. jkjjkhj
    jkjjkhj New Member
    Thanks! I hope it is not quitting on me, but I will keep that in mind!
