Dat Cantankerous Entune
Discussion in 'Prius c Audio and Electronics' started by Ghoti, Feb 26, 2013.
  1. Ghoti
    Ghoti Member
    101
    Arizona
    Getting Entune to play nice with my phone (a Nexus 4) is always a project if I want to use the Internet-connected apps (e. g. gas prices, Pandora). Once in a while, if I go into Bluetooth Settings > Paired Device List > My Phone and Disconnect All and then Reconnect All, it might connect to the Entune app. Maybe. Frustrating. More so because, any time I try and fail to connect, the entire Entune system will reboot about three to five minutes later. Anyone have or know any workaround for this?
    Also, why does it take so long for voice recognition to be available? Seems I need to sit in the car for two or three minutes before I can use that feature. It worked instantly in my '05 Prius.
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I never have any issues with the bluetooth connection. Not all phones make work with it. I Wouldn't see why Android phone wouldn't though. Make sure you have the latest version of Entune and Android And yeah at first voice command ins't readily available takes a minute or two I don't use them much not a big deal really.
  3. mwbprius
    mwbprius Junior Member
    22
    Connecticut
    I have a Nexus 4 also. I think it's too new for Entune. My Droid X worked perfect with the apps. Pandora displayed. With the Nexus 4 my contact pictures do not download and Pandora audio only works. Toyota should down load a update to support newer phones. I bet Tesla does. Any comments Mitch in MA?
  4. MBRGuru
    MBRGuru Member
    255
    26
    Probably starts VR up after everything else and then it has to prep for all the phone contacts. How many contacts do you have in your phone? My HDD system takes a little while but not too long.
  5. PriusC-illa
    PriusC-illa Member
    153
    63
    NYC/NJ
    There is an entune update from March (2.2) but it has to be done via the dealership.
  6. Ghoti
    Ghoti Member
    101
    Arizona
    Thanks, I saw the other thread with the TSB number (0051-13); that's on my todo list. I've noticed that also fixes the map's "night mode" not working if the map is started while the headlights are already on.
    PriusC-illa likes this.
  7. Ghoti
    Ghoti Member
    101
    Arizona
    Ironically, it's not that the Nexus 4 is too new for Entune, it seems that the problem is actually that the new Bluetooth stack in Android 4.2 dropped support for a lot of sub-protocols (like MAP) that Entune needs to work properly.
  8. PriusC-illa
    PriusC-illa Member
    153
    63
    NYC/NJ
    thats pretty lame
  9. Ghoti
    Ghoti Member
    101
    Arizona
    Yeah, I agree. I've heard rumors about an upcoming Nexus 4 firmware update; I have my fingers crossed that it'll bring MAP back to Bluetooth.
