Prius pulling an RV? What do you pull !!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by engerysaver, Jun 16, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    I received my scangauge 2 yesterday, installed and very happy with it, now I have a question for all. The way I set it up are:
    1. water temp
    2. RPM
    3. volt for battery "12 volt"
    4. ????? " I can not find the one for water inverter temp or MG1 or MG2. " would you guy please show me.
    by the way my scangauge firm ware is 4.12
    V/r
    Khoi Nguyen
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't know anything about towing but I've seen plenty of tiny European sedans pulling travel trailers. Litigation sounds about right for why it's not recommended in the US.
    The Great American Anti-Towing Conspiracy | The Truth About Cars
    WE0H likes this.
  3. Former Member 68813
    3,524
    983
    US
    I think it's a cultural thing. In Europe, most would walk/bike/ or use public transportation to commute. Here in US, many feel you need to have V6 powered SUV or pickup truck to do just the same (I'm not even talking about towing here). The owner manual writers just confirm to the cultural stereotypes.
    mmmodem likes this.
  4. nycaznmike
    nycaznmike Junior Member
    17
    nyc
    I had a two inch hitch installed on my prius and just ordered a direct fit hitch wiring harness
    I 've pull a 4x8 harbor freight trailer loaded with lateral file cabinets or construction equipment.
    I've installed a cargo carrier w/ aluminum tool box
    I've installed a bike rack w/ 2 bike carrier
    I've installed a harbor freight aluminum cargo carrier w/ hot water heater on it.
    I've towed a teardrop camper.
    I've being eyeing this camping trailer but hesitate to purchase since it's 1000 lbs unloaded.
    How do you monitor the inverter temperature? One big complaint is how the rear end really dips when loaded w/ stuff on cargo carriers. I'm thinking about getting those airbags too but wasn't ever able to find them. If you guys can figure out a place to purchase it.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    Load the trailer so the tongue weight isn't so much. Buy a ScanGauge 2 to monitor inverter temps and also lots of other things if you like. They are very handy to have :)
    Mike
    Mobile on my SGH-i717
  6. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    how you set up for inverter coolant temp.?? please show me, I already set up for the water coolant temp but did not know how for inverter coolant temp. and set up for MG1 or MG2 please show me how.
    V/r
    Khoi nguyen
  7. nycaznmike
    17
    nyc
    My car is at the dealership today for synthetic oil change. Since i'm towing, what other work should I have done? I'm thinking about changing the inverter and transmission fluid. I have a scan gauge also, but don't know how to monitor the inverter cooler temps.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    I'd change all the fluids if you can just for peace of mind :)
    Mike
  9. nycaznmike
    17
    nyc
  10. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    Again; this thread is about what your Prius pulls with total weight of trailer, with cargo. Please read post # 1.
  11. engerysaver
    426
    133
    Tyler, Texas ; USA
    This is my 4th trip pulling my RV ( post # 1 was my 3rd trip ). Again my trailer weight is about 1900 lbs, with about 530 lbs in the Prius. But this time I did not take a route that was less hills and level ground, I took the main roads, driving 55 to 60 MPH; On I-20 I drove 65 MPH. I went 138 miles, using 6.8 gallons of gas = 20.29 MPG. I had some head wind. Outside temp. 76 to 80 F.....water temp. 197 to 200 F.....MG1 -highest 309 F (avg 290-296 F).....MG2 highest 260 F ( avg 242 F).....ICF highest temp. 116 F.
    Long hills at higher RPM,s made all temps go up; also faster speeds did the same. No bells sounding or lights coming on!! No codes!!
    What do you pull with your Prius? Please post!!
  12. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    damn damn!!!!!!!!
    you are the man in my book!!!,
  13. markabele
    5,084
    1,782
    Nebraska
    This is awesome. Make sure to keep us informed on how everything is working or any breakdowns. How many miles on the car right now?
  14. engerysaver
    426
    133
    Tyler, Texas ; USA
    My Prius runs great, with 36,996 miles on it; oil is OK , at the correct level. I know I,m pushing the limits!!
    markabele likes this.
  15. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Engerysave
    The Sky is unlimited:) , maybe our Prius too:)
    I did installed the F-4136, I like it and I did the test show how it handle with 2 people in the Hatch back and 2 people in the rear seat, also a bag of salt for my water softener.
    212 lbs
    175 lbs
    175 lbs
    150 lbs
    40 lbs bag of salt
    total 752 lbs
    as you can see only drop about 1.5 inches with 4 people in the back and I only pump up 15lbs of both balloon.
    V/r
    Khoi nguyen
  16. Former Member 68813
    3,524
    983
    US
    The max temp on MG1 is 162C. You are very close.
    Source: Mg1 & mg2 temperature??? | PriusChat
  17. engerysaver
    426
    133
    Tyler, Texas ; USA
    Air springs works great for a better ride. The more air, the stiffer the ride!! I,m pulling about 1900 lbs with about 30 to 35 lbs in the air springs. Don,t over do it, with too much air?
    * Remember not to go over 200 lbs on the class 1 hitch. *
    1prius likes this.
  18. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    engerysave
    understood, I won't do over 25 each side, that the max that said in the instruction, you have 30-35 lbs each side ?
    V/r
    Khoi Nguyen
  19. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Prius got two ac MG which can produce quite large torque. Gen 2 can make 295 ft lb of torque.
    But don't pull too heavy as the clip. The small French R. pulled too heavy and burn it's engine.
  20. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I think what he is saying is that because of the trailer load the car is in the power zone all the time to maintain highway speeds. Not a reference to accelerator pedal travel.
    Travis
