TPMS INITIALLIZE?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Jun 26, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    Have my car for 3 years and very happy with it:), however I just find out that all wheel have TPMS!!! and I do not believe it had been INITIALIZE ????? and I never see the TPMS tire warning when I start the car, so this is my question.
    1. I am ready to change another sets of wheel, if it never been INITIALIZE then I will not see the TPMS warning light right?
    2. If I buy a second set of TPMS will the prius will take the second set of TPMS and also keep the first set in ECU?
    V/r
    Khoi Nguyen
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,738
    Bay Area
    I don't know about the first question.
    But for the 2nd question, if you buy the set, you should have the dealer set up your TPMS using their techstream. The TPMS have serial number on them, so they will be using those number and input it into the TPMS system memory in the vehicle. Your original TPMS serial is gone and will be replaced by the 2nd set you bought. I hope that helps? lol...
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Your TPMS system was initialized at the factory or the dealership. You do not have to do anything.
    If you have not had a leak in a tire and low tire pressure then you would not have seen the TPMS warning light. I do not remember ever seeing the TPMS light when I start the car. I had a screw in one of my tires that resulted in a slow leak and a TPMS warning light. It worked just fine.
    There is a TPMS button next to the OBDII connector, about where your right knee rests. Pushing this button resests the pressure setpoint for the TPMS system. If the tire pressure falls about 25% below this setpoint then you get a warning light.
    NutzAboutBolts answered your question about the second set of tires.
  4. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    There's a TPMS sensor that can be programed to match your original TPMS code so you can swap wheels without reprogramming the ECU. No experience with them, but it seems the way to go.
