At the jiffy lube
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by felix mizioznikov, Jun 26, 2013.
  1. felix mizioznikov
    felix mizioznikov Junior Member
    42
    Toyota care over, dlr closes at 5. So far so good at the jiffy lube. Washing windows, vacuum, free Keurig coffee. Oil change and filters for 30k srvc.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Friends don't let friends go to iffy lube.
    michinnom likes this.
  3. bisco
    52,390
    who knows what they're putting in there for earl?:cautious:
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    They striped a Oil pan drain plug on me years ago on a Honda Civic. Never go back.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,730
    1,767
    Bay Area
    why not do it yourself? its easy... and Jiffy Lube is the last place I would trust my Prius with lolz...
    JMD likes this.
  6. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    make sure they put 0w-20 at the proper level
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    They also like to toss out the washers on the drain plugs.
    JMD likes this.
  8. michinnom
    michinnom Member
    162
    29
    few years ago i went in for an oil change, i paid, and was on my way. while on I-5, my car overheated along a dangerous curve known as the Terwilliger curves. rainy and slick, downhill, rush hour, very dangerous, especially on the shoulder barely wide enough for a compact. opened my hood and saw the radiator cap sitting on top of the radiator with fluid all over the engine bay. called iffy lube and the loser says to me, why don't you bring it in tomorrow since we're getting ready to close and we'll take care of you then. i told the loser that i'm stranded and asked him to either bring me coolant and water or come tow my car to his iffy lube. he says no. luckily for me, i had a gallon of emergency water in the car and managed to get the car off the next exit. walked to a local store and bought coolant and water myself. then drove to iffy lube and this loser, from the phone call, was locking up getting ready to leave. i had to twist his arm to re-open the shop to drain my radiator and re-fill. while he's doing this, he's on the phone with one hand and filling my radiator with the other spilling it all over the engine bay not even paying attention. next day i call this iffy lube and explain. then i called corporate and that same day the regional manager calls me profusely apologizing about the bad apple and offers to clean the engine bay and give me some free service. didn't take his offer and never went back to any of them. good luck.
    JDB and JMD like this.
  9. JDB
    JDB Junior Member
    24
    That's a darn shame. THAT's the reason I'd rather do things myself.
    Chris S likes this.
  10. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    Everytime you go to Jiffy Lube, God kills a kitten. True story.
    Jonny Zero likes this.
  11. felix mizioznikov
    42
    Omg what have I done. My engine blew up, tires fell off, and the key transponder is melting...MELTING.
    come on guys, I put 500 miles on it today and running fine.
  12. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    They had right oil?
  13. Bill Norton
    Bill Norton Senior Member
    2,218
    745
    MONW, Ks.
    2019 Prius
    L Eco
    I like how they made sure they had the car level in the picture you attached.
    It's the important details like that, that make them so ,,,, special....:rolleyes:
    Did you see them pour 0-20W syn in there?
    Did you check the oil level the next day just for grins?
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Well then, that is absolutely conclusive, 500 miles without your engine blowing up is proof the Jiffy Lube is ethical and knows what they are doing
  15. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The stealer stripped the drain plug on my son-in-law's Camry. All the crows in the world is black.
    Do the oil change DIY.
    JMD likes this.
  16. abistro
    abistro Junior Member
    22
    Virginia
    I agree with the above statement. Jiffy Lube is horrible, make sure you double check all the work they do... even then I wouldn't go there.
  17. Sfcyclist
    1,621
    376
    SF, CA
    PC member aren't too fond of JIffy Lube BTW.. just in case you didn't notice.
    JMD likes this.
  18. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I guess each person needs to learn the hard way about things like this. Might get by just fine for a few changes, but eventually the lesson will be learned - hopefully without a lot of expense or trouble.
  19. Sfcyclist
    1,621
    376
    SF, CA
    I have to admit, I worked there was I was in High School.. boy did I learn a lot.. what NOT to do! lol..
    SoCalBPrius likes this.
