How do you remove the hoses from the inverter coolant pump?
Discussion in 'Generation 1 Prius Discussion' started by kfl407, Jun 28, 2013.
  1. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    Hello, I am replacing the inverter coolant pump and am not sure how to remove the hoses from the pump. It looks like you squeeze together the three tabs on the clamp with your fingers but it is a very tight space to work in and I can't get it to budge. Am I doing it right? Thanks
    donbright likes this.
  2. bwilson4web
    15,405
    Photo?
  3. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    Yes I am attaching two photos of the clamp on the hose that attaches to the inverter coolent pump from two angles. I could not get a good close up so I also took two photos of the clamp that attaches the coolant hose to the bleeder valve. It looks very similar but is smaller and it is gold in color. Also can the clamps be re-used after they are removed? Thanks
  4. usnavystgc
    3,159
    988
    Tucson, AZ
    You won't be able to do it with your fingers. You will need to use a pliers of some sort. A regular pliers will work but a water pump pliers (aka channel lock) is my preferred tool. Squeeze the tabs together and slide the clamp down toward the middle of the hose until it is completely off the nipple the hose is attached to. Then you will have to break the seal that the hose has on the nipple. I typically do this by turning the hose cw/ccw (alternating) and pulling the hose away from the nipple. They won't come off easily because they have been "heat" sealed for many years. All clamps and hoses are removed the same way and can be reused.
  5. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    I had already tried using different size pliers including channel locks but the space is to tight so that is why I was trying to use my fingers. I just tried again but I don't see any way to do it in that space. Is there some other kind of tool that might work?
  6. Patrick Wong
    18,199
    6,464
    I've changed the inverter coolant pump on 2G but not Classic.
    Would it help to remove the bolts holding the pump down first? The idea is that maybe if you can lift the pump up you will have better access to the hose clamps...
    Alternatively, you may need to remove the front bumper cover and headlight to gain better access to the pump.
  7. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    Those bolts have been loosened but it doesn't help much. I have also loosened the bumper cover and removed the headlight.
  8. Patrick Wong
    18,199
    6,464
    Sounds like you've done everything possible to gain access to the pump, so now you might need to purchase a tool that will allow you to squeeze the hose clamp ends together in order to remove the clamps.
  9. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    It sounds like you may be right. Hopefully someone on here knows what that would be. Otherwise I may have to find someone else to do it.
  10. ChapmanF
    15,107
    I usually find that once it pops loose and will twist on the nipple at all (that's the hard part), getting it the rest of the way off isn't nearly as difficult. After going through all that, before I reattach hoses, I'll take just the tiniest dab of silicone brake/dielectric grease on a fingertip and smear an invisibly thin layer onto the nipple. It's amazing how much easier that will make removing the hose next time (if there's a next time).
    -Chap
    usnavystgc likes this.
  11. usnavystgc
    3,159
    988
    Tucson, AZ
    kfl,
    Stick with it. You can get to them. Keep looking for a way. If someone else can do it, you can too.
    PS: There is no special tool. The only tool you can use besides pliers is maybe a small c clamp.
    donbright and kfl407 like this.
  12. jm101
    jm101 Junior Member
    17
    ozark al
    A pair of needle nose with a 90degree angle take the 2 bolts loose that hold pump in place then you can move it a little to get a better position on the clamp.
    kfl407 likes this.
  13. Mendel Leisk
    38,247
    Once you get the clamp loosened and parked away from the joint, take a broad bladed screw driver tip, place against the end edge of the hose and push hard, while pulling moderately on the hose. Move the screw driver tip around to another point on the edge and repeat. You should be able to get the blade to about 180 degrees of the circumference, and all this concerted pushing/pulling should break it loose. Just persist.
  14. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    Great suggestion. Thanks.
  15. jm101
    jm101 Junior Member
    17
    ozark al
    I just replaced my inverter pump 6 months back, Also get some fish tank air hose from pet store for the air bleeding process it is clear see thru you can see the air bubbles and the flow.To get all the air out is difficult and time consuming but it will work out. jim
  16. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    I found some at lowes in the plumbing dept. with 3/16" inner diameter and 4/16" inner diameter. The 3/16" is very tight and barely fits on so that I am afraid it might rip. The 4/16" is somewhat loose so that I am afraid it will leak. Do you know the inner diameter of the fish tank air hose? kfl407
  17. jm101
    jm101 Junior Member
    17
    ozark al
    Sorry I don't ,Also medical tubing for air machines and personal vaporizers work well if you can take the bleeder screws out and take one with you to pet store you can check fit on hose. jim
  18. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    I unbolt the pump from the frame by removing the two 10mm bolts on the mounting bracket. Then swing the pump around until you can get 45 or 90 degree large needle nose pliers (harbor freight ones are good enough) onto the clamp "ears". Squeeze the clamps and slide them down the hose. You need to twist the hose to break them free, they can be seized onto the pump.
    Tip, you can twist/yank the OLD pump out of the rubber mount on the bracket. You may need to bend the metal tabs that hold the rubber in place. Since you are replacing it all it's easier to yank it out by destroying it than remove the bolts sometimes. Once the pump is out of the way you can remove the bracket and get ready to install the new one, but install the hoses onto the pump then bolt the new mount to the frame. Don't forget the electric connection.
  19. jm101
    jm101 Junior Member
    17
    ozark al
    Good morning all. Any updates from OP would be nice. So many never post how it went.Did everything work out need help bleeding out air from pump system. jim
  20. kfl407
    kfl407 New Member
    Clermont, FL
    2002 Prius
    Update- I was able to finish replacing the inverter coolant pump the following Sunday
    thanks to the helpful suggestions on here especially jm101. Jpmedigroup's video on youtube
    was also very helpful.
    It helped me also to remove the small hose that goes to the bleeder valve which allows
    easier access to the pump. Once the front hose is removed from the pump, the back hose is
    easier since the pump is then easier to move around.
    I did the air bleeding process per the instructions in the Haynes manual which basicly says
    only two repititions are required followed by running the pump for five minutes. It took me
    three repititions instead of two. kfl407
