no beeps when entering/exiting EV mode
Discussion in 'Gen 2 Prius Accessories & Modifications' started by kyleroden, Oct 4, 2007.
  1. kyleroden
    kyleroden Junior Member
    I just finished installing an EV button in my 2007 touring. It works fine, and will beep 3 times if it cannot enter EV mode, but will not beep at all when entering or exiting EV mode. I was for sure I had read that there should be a single beep when turning EV on or off.
    Would appreciate it if someone would let me know what the deal is. This is a stand alone momentary button and not the coastaltech cruise control mod.
    thanks!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    No beep if you're already on the Energy screen. But if you're on the consumption or any other screen there will be a beep when it switches over to the Energy screen...as it always does when you enter EV mode.
  3. kyleroden
    thanks for the reply.. and thanks for the guide on installing the button, it made it very simple. I'm generally on the energy screen so I suppose thats why i get no beeps.
  4. efusco
    19,891
    1,195
    Nixa, MO
    No problem, that's why I get paid the big bucks!
  5. ACORNBLUES
    ACORNBLUES New Member
    87
    Disabling beeping also affects behavior.
    <div class='quotetop'>QUOTE(kyleroden @ Oct 4 2007, 03:41 PM) [snapback]521345[/snapback]</div>
  6. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    <div class='quotetop'>QUOTE(efusco @ Oct 4 2007, 04:44 PM) [snapback]521347[/snapback]</div>
    For reference, my EV button works perfectly. However, I do NOT get a beep whenever I activate or disable the EV mode... no matter what screen was being displayed at the time. The only indication that I've entered EV mode, is the MFD will switch to the Energy screen if I was on the Consumption or Climate screen. Again, no beep. I do get the three beeps when the car will not allow me to enter EV mode because of low SOC, speed threshold, etc... I have the OEM switch from Sigma on my 07 Prius.
  7. Tim Wang
    Tim Wang Junior Member
    33
    Central Illinois
    Just finished the EV mod on my 2007 Base model, I think I have the exact same problem, no beep going in or exiting EV mod. Haven't heard the 3 beep when it's got canceled, or pushing the button while ICE is running. I do also have the screen come back to Trip Info if any other screen is displayed....
    Any of you have some solutions on this yet? I don't know what mode I am in right now....
