Where to get a replaced charging cord
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by brian brooks, Jun 29, 2013.
  1. brian brooks
    brian brooks Junior Member
    17
    I ran over over my charge cord , is there a generic cord out there or a replaced guncharger.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
  3. brian brooks
    17
    where do you get it connected to the good power converter
  4. bisco
    51,961
    there are a number of them on the market now. the quick one (1 1/2 hours) are as cheap as $4-500. there are some threads here with links, or maybe peef can repair your cord and convert it to 230v.
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) Which EVSE do you have? Factory Prius or Level 2? I assume the plastic connector, handle is damaged/broken.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  7. markabele
    5,084
    1,782
    Nebraska
    I assume he is talking about his factory charger as the one that is broken. :)
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
  9. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    What is damaged on yours? the brick, the plug or the cord itself?
  10. brian brooks
    17
    It is amazing how tough the charging gun it is now working and everything is OK how do take the black asphalt off the gun
  11. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) Dampen a cloth with some mineral spirits or turpentine. Gently wipe until it's clean.
  12. F8L
    19,011
    4,083
    Grass Valley, CA.
    Bug & Tar Remover should work well too. You can find it at any store that sell automotive parts.
  13. bisco
    51,961
    but not while plugged in!:eek:
    F8L likes this.
  14. Beshara1111
    Beshara1111 Junior Member
    57
    Can the quick 240v charging cables ALSO be used on a 120v outlet? Would this work for PIP?
    Leviton A2034-Pev 30A 20 ft Charge Con I'm thinking of buying a PIP without it's charging cord..
  15. bisco
    51,961
    i'm not sure what you're asking. but i think there are models that work on 120 and 240v.
  16. Socalju
    Socalju New Member
    Los Angeles
    So we can get the 240v EVSE upgrade, the $25 adapter, plug in to a standard outlet and charge twice as fast? Please confirm. Sounds too easy. Thanks.
