Replacement for scuffed factory default wheel cover?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by motifone, Jul 2, 2013.
  1. motifone
    motifone Junior Member
    48
    Hi everyone,
    I have a 2012 silver Prius with the original factory wheel covers (is that what you call them)? They seem to be made of plastic, and I believe a lot of folks actually remove these for aesthetic reasons.
    Anyhow, I pulled up a bit too close to a deep curb and scuffed one of the covers pretty good. I'd like to replace it if possible. Are these fairly cheap? Where can they be had? Are they easy to remove and put on?
    Not really looking to upgrade the covers... just replace the damaged one
    Any input appreciated thanks!
  2. Former Member 68813
    3,524
    981
    US
  3. WILLIAM ZYRKOWSKI
    WILLIAM ZYRKOWSKI New Member
    Prospect Heights, Illinois
    Have Seen them on Ebay for around 35 dollars
  4. WILLIAM ZYRKOWSKI
  5. yrrebbob
    yrrebbob New Member
    I had a similar problem, try a very light sanding on the damaged wheel cover, as not to scratch the plastic any more, but to smooth out deep scratches. Repaint with Touch"n tone Spray paint #55273830 Aluminum. You'll be amazed at how good it will look. At any rate you can keep the repaired cover as a spare. Good Luck!
  6. ETP
    2,801
    1,170
    Auburdale FL
    Buy Toyota hub caps and throw the wheel covers away. The wheels are gorgeous!
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Don't you mean centercaps? ;)
  8. ETP
    2,801
    1,170
    Auburdale FL
