2010 Prius - Brakes - Need Toyota regional management contact for NYC area
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Edweissman, Jul 5, 2013.
  1. Edweissman
    Edweissman New Member
    I have a 2010 Prius and I live in Bronx, NY. I have been having my car serviced at Westchester Toyota. In mid April, the master cylinder failed at 90,000 miles, and the replacement cost me $2500 plus the cost of renting a car for a week. Yesterday (7/4) the brakes failed again; the ABS light and warning beeper come on as soon as I start the car, and I have no brake pressure. I called Westchester Toyota, since they did the repair in April, and they told me that since more than 1 month had passed, there was no warranty on the work they did on the brakes. I'm bringing the car in to them this morning, but I think that replacing the brake assembly TWICE in less than 90 days is ridiculous. In my mind, either the unit they installed was defective or the work they did on it was defective. I want to get in touch with Toyota regional management to discuss this with them; I do noit feel that I should have to pay for this work to be done twice. Can you give me an address (email preferable) of a contact for the regional manager whose territory includes NYC and Westchester?
  2. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    You need to check to see if your Prius falls under the recent brake recall also.
  3. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Toyota repair parts usually have a 12 month warranty. Your dealer is not treating you as they should and does not deserve your business. Call Toyota Customer support at: 1 (800) 331-4331 to get help.
    JeffD
  4. ShannahQuilts
    ShannahQuilts Junior Member
    My guess is that it's not the actuator, but the accumulator. You might have them
    look up recall D1H (that's a number one). Here's what I was told, and I was told
    that this came from Toyota:
    "The subject vehicles are equipped with brake
    pressure accumulators consisting of a metal plunger containing brake fluid encased in a metal housing. The
    plunger is designed with metal pleated bellows to allow for motion. Nitrogen gas is sealed between the plunger
    and housing. There is a possibility that a fatigue crack could develop in the bellows due to the vertical vibration
    of the plunger while driving. If this occurs, nitrogen gas could leak into the brake fluid and gradually cause the
    brake pedal stroke to become longer, resulting in decreased hydraulic pressure. Under certain circumstances,
    this condition could affect stopping distance and increase the risk of a crash."
    I took my car to an independent mechanic who examined the brake fluid and found bubbles (presumably
    nitrogen) in the brake fluid.
  5. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I'm pretty sure this is not what Toyota would expect from their dealership... Please call the number above and let us know what happens!!!
