2013 Scion FRS Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by firemechanic, Feb 1, 2013.
  1. GloryThief
    GloryThief Junior Member
    59
    The Westside
    2013 Prius v wagon
    Those spacers look good!
  2. eddieEndo
    eddieEndo New Member
  3. J. Ramirez
    J. Ramirez Junior Member
    Hey Firemechanic. I just got the same set of wheels and plan to buy the same spacers you did. How are they so far? Were you surprised that they came in @ 3.5mm rather than just 3mm? Also, did you request for the new hub ring to be 10mm or is that the length they would have cut it to anyway? How is the fit of the new hubs to the car and to the wheel? Sorry for all the questions. I'm very interested to see how the overall experience worked out. Thanks in advance!
  4. J. Ramirez
  5. firemechanic
    firemechanic Junior Member
    Kent, Washington
    The spacers so far have been great. I havent lost torque on the lug nuts yet so everything is staying tight. I already have 4K miles on them, thanks to a drive to San Diego over spring break. The spacers came in at 3.5mm thick but thats just fine. When I requested the hat height to be 10mm the representative on the other line said that they would have made them around that height anyway. I always like to be sure so I specified all measurements. If you need specifics, contact info or maybe the job ticket # let me know.
  6. Bill Norton
    Bill Norton Senior Member
    2,141
    732
    MONW, Ks.
    J. Ram,
    Or you could stand-by. I'm going to try to install my set of these wheels this weekend and my plan is to use a sanding disc on a high speed and blend off 3 mm from just the corner edge of the caliper mount.
    I'll post detailed pics when I do it.
  7. J. Ramirez
    Thanks Bill! Looking forward to hearing about your results.
  8. J. Ramirez
    With same custom spacers as firemech
    mshl726 and firemechanic like this.
  9. benny818
    benny818 prius convert
    Bay Area, CA
    Those wheels look awesome. i'm actually leaning towards them as well. Just waiting on the spacers to arrive. I was wondering what kind of mileage are you guys getting on the frs wheels now? better/worse?
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    Worse if you came from 15" wheels.
  11. firemechanic
    Kent, Washington
    Definitely worse than stock 15's but I'm getting about the same as my old 17" MOMO's with MXM4 LLR's. I've put 10k on my FRS wheels (with the stock Michelin Primacy tires) and I'm averaging around 46.5MPG driving normally......as I call it. I tried maximizing my mileage awhile back through two tanks of fuel and I averaged 51 MPG but it drove me nuts. It was hard and I'm not partial to being flipped off and honked at for holding up traffic.
    benny818 and F8L like this.
  12. benny818
    Bay Area, CA
    Ha! I'm currently on oem 17" wheels so the that's good to know that I won't realize too much of a loss in mpg. Man can't wait for the spacers to come in. Anyone know a place to get a decent set of tpms for them? Mines unfortunately did not come with them.
  13. firemechanic
    Kent, Washington
    I have a spare set of 4 from my 2007 Camry. They are the exact same sensor with the same part #. I don't know what they are worth but make me a fair offer and they are yours. I can sent detailed pics if you want. I you don't need them this offer is open to anybody.
  14. Mr. Ant
    Mr. Ant New Member
    I found someone in my city selling his FRS wheels, but without the tpms sensors. Is it possible to use the sensors I already have and install with the new wheels?
  15. firemechanic
    Kent, Washington
    Yes.......The sensors in the Prius wheels will fit the FRS wheels.
  16. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    They say you should install them with new sealing gaskets though. But that's just to CYA, you should be ok as long as the gaskets are in satisfactory condition.
  17. Mr. Ant
    Mr. Ant New Member
    Thanks for the info. Are the spacers necessary or mostly for aesthetics?
  18. xliderider
    8,140
    3,274
    Honolulu, HI
    They're necessary, without them, they don't clear the brake caliper holders. Other members were to try to grind away a couple millimeters off the caliper holders to clear the wheels, but AFAIK no one has posted back with results or pictures.
  19. benny818
    Bay Area, CA
    Sorry for taking so long to reply, been away from the forum due to having surgery on my back. Not fun at all. Know if all I gotta do is put those sensors on and it would work right away? No programming needed? I'm not in any rush now since I can drive for a bit until I'm fully recovered. the wheels just sitting in the garage now waiting to be put on.
  20. xliderider
    8,140
    3,274
    Honolulu, HI
    You would need to have them programmed at the dealer, or by someone who has techstream.
