hitch for our c?
Discussion in 'Prius c Accessories and Modifications' started by dolfanpete, Apr 16, 2013.
  1. dolfanpete
    dolfanpete Junior Member
    60
    Naples, Florida
    Can a hitch be installed and to what capacity can it tow if possible? Is there a suggested weight that it can tow?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    There's a walk-through thread on here somewhere with pictures and everything.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Toyota does not recommend any towing so don't pull a 20 ft boat.
    TheyCmeNow likes this.
  4. dolfanpete
    60
    Naples, Florida
    ote="xpcman, post: 1782474, member: 51805"]Toyota does not recommend any towing so don't pull a 20 ft boat.[/quote]
    How about 2 bikes. Or a kayak on a kayak trailer?
    Dylan Murphy likes this.
  5. stopint
    stopint Junior Member
    22
    Cincinnati, OH
    i just had my hitch installed a couple of weeks ago...but i only use mine for my bike...posted pic
  6. Sherrynlew
    Sherrynlew Junior Member
    West Ghent, New York
    I've looked into getting the hitch for an upcoming road trip. They say it's an easy install. I want to know is there any contact with the body, I don't want any rubbing. They could not say as they have not installed on a Prius c yet.
    tgpii likes this.
  7. stopint
    22
    Cincinnati, OH
    this time around i just took it to a place and they installed for $50...i installed a similar hitch on my 2nd gen prius back in 2005...it was tedious to say the least and i am sure this install would've been the same...i just did not feel like dealing with it...
  8. blumenla
    blumenla Spontaneous Adventurer
    25
    Rhode Island
    I was thinking of going to Uhaul because the whole hitch and installation is only around $150-$200, any thoughts on this being a bad idea?
  9. TheyCmeNow
    TheyCmeNow Junior Member
    77
    25
    I just ordered the CURT Manufacturing 11299 Class 1 Trailer Hitch, Pin and Clip off of amazon. Looks easy to install.
  10. TheyCmeNow
    77
    25
    Damn! That was a hard install! :mad:
    I had help from a friend and it still took us over an hour!
    But hopefully it is worth it..
  11. C me now
    C me now Junior Member
    24
    24
    Eureka, CA
    I just installed the curt hitch. It took me an hour start to finish. Good quality product. Good welds, nice paint, and good instructions.
    I bought it through amazon and it arrived within
    3 days.
    I recommend the hitch.
  12. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    What was the hard part? I did have to swap one factory bolt with one in the kit. That was pretty much the hard part for me.
    Dan
  13. TheyCmeNow
    77
    25
    It's hard when you have to remove the bumper support, support it with one hand, and try to properly thread the new screws in place. That sucker was heavy! I thought it was easy based off of the product photo but everything was a tight fit. Still worth it.
  14. WD0AFQ
    619
    152
    Dexter, Mo.
    Oh. I removed only the plastic air dam under there and bolted mine right on. I think it had 4 bolts. I used 3 original Toyota bolts and one from the kit, it was longer. I think I had a thread on installing mine about 5 months ago.
    Glad you got it on. Its nice to know it is there if needed.
    Dan
  15. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    So far ive only used mine 2x but loved it. Just use mine with a cargo bag or putting a double stroller on it for our road trips.
    SGH-T889 ? 2
  16. mahout
    mahout Active Member
    655
    116
    NC
    Owners manual says Prius C will not tow anything. For those of us who outfitted Honda Fits with bicycle trailers in spite of their warning we would recommend a trailer including payload not exceedding 500 lb but that also REQUIRES the use of airlift shocks to prevent rear sag and difficult steering. Memory says Monroe MA890 but look up prior posts here to be sure. They are about $66 a pair and are direct fit.
    Requiring airlift rear shocks is not a typo; you must install them unless you want a tail happy trailer and very nervous driving. dangerous as well. Somebody out there probably makes a hitch for the Prius C just like Honda Fits. Check ebay, it oesn't look very difficult to make.
  17. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Memory and the ~15 posts you created about this topic.
  18. Pierce Butler
    Pierce Butler Junior Member
    I have a trailer hitch and light kit installed on my Prius C. I have a 125 lb sport trailer which was previously towed behind a motorcycle. Loaded with about another 75lb worth or luggage and about another 200lb in the back the cars suspension is not taxed and car handles normally without even any indication that it is towing anything behind it. Fuel economy is only slightly impacted by the trailer. In fact as long as you are not exceeding the max capacity of the car a small trailer, such as the one I am using, will have less impact on the suspension than loading all the weight in the rear of the car; the leaf springs on the trailer are taking the majority of the weight and not the suspension of the car.
    tgpii likes this.
  19. SummerRain
    SummerRain New Member
    Ann Arbor, MI
    Instead of purchasing and installing a hitch, we went with the Sea Sucker Bike Rack [Talon] option. It works well and stays attached for many driving hours, especially in cooler weather [November] in Michigan.
    The only downfall is, you have to remove the bikes front tire to install it to the bike rack.. However, they do have other options to chose from.
  20. johnhlong
    johnhlong Junior Member
    89
    29
    East Carbon, Utah, USA
    What light kit did you use?
    John
