Oil Overfilled by 1/8 in is that a problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by havanese_boy, Feb 10, 2006.
  1. havanese_boy
    havanese_boy New Member
    Tennessee
    I took my Prius in to Roberts Toyota in Manchester, TN yesterday for the 5k oil change and tire rotation.
    I took my own Mobil 1 5-30 and filter and they changed the oil for $10.00 and rotation the tires for $14.99. A good price if you ask me.
    But when I got home, I remembered from reading on the forums that I should check to see if they overfilled the oil. Sure enough the stick read about 1/8in over full. That made me mad as I told the person doing the job as well as wrote it down on a piece of paper with the oil and filter to not overfill and to check the level after pouring in 3.5 qts.
    Just how big of a deal is 1/8in overfill? Should I raise a stink with the services department/salesman or let it go this time and have them check the level before I leave the lot the next time I get the oil changed?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    1/8" probably poses no problem as that seems to be where the oil level is on the dipstick when the cars arrive new. I think Toyota needs to review this whole issue and make some difinitive statement on it. If you drain the oil and replace the filter and put in what they call for your 1/8" over the full line. Just drive it, if you find that your mileage has dropped it's probably the tire rotation that's the culprit, did you check the tire pressure? That would be the first thing I did after a tire rotation.
  3. havanese_boy
    Tennessee
    Sounds like a good answer...the tires where at 43 front and 40 rear, which is what I asked for them to be...
    I am noticing a slight pull to the left now, so might need to take it back for an adjustment.
  4. jeromep
    jeromep Member
    827
    Eastern Washington State
    It is not a deal to worry about at all. Any vehicle dipstick isn't a precision measuring device. It is a ballpark measuring device. If it were precision it would have graduations that would indicate the actual quantity of oil in the sump, however that is not the purpose of a dipstick. My oil has been somewhere betwen 1/8 and 1/4 inch over the top dot since it was new on a factory oil fill.
    If anyone has ever seen a cross section of the ICE with the diagram of the dipstick installed and an indicated full oil load you learn a couple of things.
    1. 1/8 inch, 1/4 inch even 1/2 inch over "overfill" is not an issue when considering crank slap. If you do a 4qt fill at every oil change then you will end up with about 1/8 to 1/4 inch above full dot, but many, many inches below the crank. But this is the standing oil level, not the running oil level. The distance from the crank to the top of the normal full mark is very high, at least a couple of inches.
    2. The vehicle is going to pump a great deal of that oil into the galleries and passageways of the ICE while running. So, oil level is going to drop dramatically when running, potentially the sump will be drawn down 1/2 to 3/4 of its full non-running level.
    Therefore a small level above the full mark isn't an issue at all.
  5. Twiddles
    Twiddles New Member
    47
    Downstate NY
    WOW! Only $24.99 total?
    I took mine in today for my first 5,000 mile oil change and tire rotation. I also brought my own Mobil 1 oil but before I went I poured out 1/2 quart from one of the bottles so they couldn't possibly overfill. Then the bill came: $70.00!!! And, that included deducting the price of the oil. I asked why the service was so expensive and they said that it was due to the labor charge for the wheel balance. Do the wheels need to be balanced every 5,000 miles? Did I get ripped off?
  6. havanese_boy
    Tennessee
    Yep, 24.99...but that was just a tire rotation and not a balance. Although it feels like that might be the next thing I have to do.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I don't think they need to be balanced until you buy new tires. Unless you have some reason, vibration or weird tire wear, to think they are out of balance.
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    They put in 4 quarts. 3.5 should be just over half way between the full and empty. When they put 4 in mine it is 1-3 /8 over the top line.
  9. havanese_boy
    Tennessee
    I gave them 4 qts, and they didn't give me anything back, so either they disposed of the leftover or something, because the dipstick on showed 1/8in over the top line.
  10. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    Twiddles, they took you for a ride. Tires only need to be balance if you change the tire on the rim or you experience a vibration through the steering wheel when you are driving.
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Disposed of it in your car! Sorry but you got a good price. The oil needs to be changed the filter needs to be changed and the tires rotated not ballanced.
  12. havanese_boy
    Tennessee
    The tires were not balanced...only rotated.
    What I am saying is now the car pulls slightly to the left so I'm going to get the alignment checked.
    Did I mention they even came and picked up my car from work for that 24.99 price?
  13. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    regarding your pull to the left:
    probably not alignment related, unless you whacked a curb recently. especially if the pull started just after the tires were rotated.
    have them swap your front wheels, left to right.
    if the pull goes away, it was likely a conicity problem.
    if it pulls to the opposite side, it can be a radial pull, or a severe conicity problem.
    the only way to get rid of it completely is to replace the tire that is causing the issue.
  14. havanese_boy
    Tennessee
    Noted...thanks everyone
  15. richard schumacher
    7,682
    1,062
    United States
    Havanese, next time give them three quarts, not four. Three is plenty, it will take them less time, there'll be no fiddling with a leftover partial quart, no worries about overfill, and you'll save six bucks. Everyone wins. (Just tell them not to add any of their own oil, and that you'll check the level on their drive before you leave.)
  16. havanese_boy
    Tennessee
    I was thinking that already...
    It's sad that we have to think of ways to avoid problems and then check their work before leaving the lot.
    It's like we are talking about children.
  17. aaf709
    3,862
    2022 Prius Prime
    I hear you. Last time I went in I gave them 3 quarts. The Service Manger was surprised I wanted to put in so little as the Prius normally took 5!! :blink: He then asked a tech who told him the correct amount.
  18. windstrings
    6,280
    378
    Central Texas
    Both of my new cars are about 1/8 over the full mark...... I plan on putting in less with my next oil change... If I have it done, I will tell them to leave the last quart, or rather only put in 3 quarts, and I will do the rest myself till I learn how much it takes. Then Ill just give them what I want the next time after that and tell them this is the oil I want to use.
    They usually have 10-30 in their barrels and I hear rumours its not that good anyway compared to that you buy in the quart containers yourself.
    I want to learn to just do it myself.
    This is an excellent pdf of how to change the oil... rather simple... as oil changes go.
  19. jeromep
    jeromep Member
    827
    Simply put. A 5 qt fill is bad. A 3 qt fill is too low for my taste. The system is rated for 3.9 quarts, which is 4 quarts. Ever seen .10 of a quart. It is about a shot glass or two of liquid. Not much. and over the surface area of the entire sump, a meaningless amount of oil.
    Just hand them 4 quarts of the oil of your choice and be happy knowing that all is well in your sump.
  20. windstrings
    6,280
    378
    Central Texas
    3.7qts with filter, 3.4 without according to specs... too much oil is not only bad for gas mileage, it causes abnormally high head pressures. I suppose it wouldn't be critical, but I won't be doing it... its too much fun to get really good mpg.
    But its everybodys choice of whether to put in "more" than the manufactuer recommends or "less".. I choose less.
    Heck.. just pout out about half of one quart and then hand it to them with the other 3 quarts.... its easy.
