Should I change out the engine coolant that was added redline water wetter?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yibo829, Jul 14, 2013.
  1. yibo829
    yibo829 Junior Member
    84
    I added redline water wetter to the overflow tank a while ago, maybe when the car was 60,000 miles, now the car has about 73,000 miles. This was about a year ago. BTW, I only added half a bottle, which means it's about 6 oz, since the whole bottle is 12 oz.
    Recently, I been reading a bunch of stuff about it's not good to add any additives to the TOYOTA SLLC coolant and the redline water wetter thing needs to be changed out because it will disrupt the integrity of the TOYOTA SLLC's properties of long life.
    So I'm not sure, now I kind of regret adding the additive to the overflow tank in the first place... Because it'll cost money to change it out. (I'm not very confident in trying to bleed the system myself... I read a bunch of posts on how to do that too. o_O)
    What should I do? Should I get it to a dealership to get it changed or just leave it be? The dealer quoted me $120 to do it.
    And if I don't change it until 100,000 miles, are there any negative consequences?
  2. frodoz737
    frodoz737 Top Wrench
    4,734
    2,526
    33
    To many people think the TOYOTA SLLC is some magical lifetime formula. It's not. Whether adding 6 oz of redline water wetter will "contaminate" it is unsure. If you feel uncomfortable about it, change it. I personally would not go more than 2 years or 30,000 miles between changes. But what do I know? I'm just a lowly mechanic.
  3. Patrick Wong
    18,210
    6,514
    I would leave it alone. I think you are good waiting until 100K miles for the first change, just look at the coolant in the overflow container once in a while. If it starts to look like there are any sediments or rust then I would change it at that point.
    ralph seifer likes this.
  4. yibo829
    84
    Thanks for your input.
  5. yibo829
    84
    Thanks for your input. I'm also wondering if the pH matters. I took a simple pH strip and tested the coolant and matched the color to the chart and it looks like it's an 8...
  6. bisco
    52,526
    slightly alkaline?
  7. yibo829
    84
    Yes. Slightly alkaline.
  8. Patrick Wong
    18,210
    6,514
    I think this is OK. If you care to measure precisely, you should be measuring the coolant in the radiator, not the coolant in the overflow container since the overflow container was filled with the Redline supplement.
    If you were serious about actually wanting the Redline supplement to enter your engine's cooling system, you should have removed the plastic cover over the radiator for access to the radiator cap. Then open the radiator cap, suck out sufficient SLLC to make room for the supplement, pour in the supplement and then top off the radiator with SLLC. Putting the supplement into the overflow container does very little to the coolant in the engine. The only exchange of fluid between the radiator and the overflow container occurs during heat/cool cycles when the radiator cap allows a tiny amount of fluid to move back and forth between the radiator and overflow container. The engine coolant heats and expands, creating sufficient pressure to open the radiator cap valve so fluid can flow into the overflow container - then cools and the resulting vacuum draws fluid back.
    If you look at the overflow container when the engine is cold vs. hot you will note the difference in fluid level is very small, perhaps 1/8" or less change in height.
    edthefox5 likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,835
    Clearwater, Florida
    Been using Redline Water Wetter in both the Ice Coolant and the Inverter Coolant for 6 years. It has a very good anti-corrosion property too it. Been using that product for 30 years. It works.
    Looked in the rad by opening the rad cap the other day when I had the plastic valence off and rad looks mint and I changed the Inverter coolant and added half a bottle to that new SLLC at 30K miles. I have very aggressive agitation in my Inverter Coolant tank and no longer see the red dust (aluminum salts) that was constantly on the cap before.
    Inverter runs very cool even down here in florida.
    Your probably acidic because its the original fluid in the car and its 4 years old. Redline WW can't fix that 4 years later. It can prevent it though. Its best to add to new fluid.
    I would get that fluid changed and the Inverter coolant changed too if you can afford it and plan to keep the car a long time and get the trans fluid changed too.
    It's a great car all you have to do is keep after the fluids. Fresh SLLC and some WW and your ICE water pump will last a very very long time. Same with the Invert coolant pump. My WW cooled Inverter pump worked perfect right up till I got it replaced with the recall 6 months ago. Didn't need replacing but they did it when I took the car in for the steering shaft recall. I made them clamp the hoses off instead of dumping the fluid as it had pretty new fluid and WW already in it. They liked that.
    Btw, I am running Redline D6 trans fluid too going on almost 55,000 miles. Car runs perfect.
  10. yibo829
    84
    From what you're saying, it looks like not much of the redline product actually got into the radiator...
  11. yibo829
    84
    Actually you are the one who convinced me to use water wetter in the car. I saw several other posts from you stating that water wetter is good to add to the coolant so last year I though I'd give it a try too. I really don't know if it helped to keep the inverter cooler or not, it doesn't really matter now because I already took the car in for the water pump recall and steering recall fixes, that was a couple months ago. So the inverter coolant is new and fresh.
    As for the transaxle fluid, I changed that myself at around 60K miles. I read quite some posts about using an alternative fluid such as redline d6, but I went with the atf ws in the end...
  12. edthefox5
    10,096
    4,835
    Clearwater, Florida
    Oh Ok. I think its a good product. Has worked very well for me for years. But really requires a fresh change of coolant to work.
    Btw, I doubt you have fresh coolant with your new pump recall as most dealers just clamp off the hoses with a duckbill, throw in the pump and then top off the coolant tank.
    You can tell if its fresh as its a very vibrant red and has very aggressive turbulence.
  13. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Alkalinity will attack aluminum.
  14. Patrick Wong
    18,210
    6,514
    I suggest the OP should test new SLLC with a pH strip and see what that shows. I believe that antifreeze will register on the alkaline side but remember that it is packed with anticorrosion agents.
  15. yibo829
    84
    I hope they didn't do that to me since the service adviser told me it was gonna be new. But what does he know lol. I actually checked the ph of the inverter coolant and it registered a high 9.5. So I'm assuming it has to be fresh.
  16. edthefox5
    10,096
    4,835
    Clearwater, Florida
    Hell, water will attack aluminum. One of the most corrosive metals.
    Whats interesting is the unbelievable amount of tiny aluminum cooling channels in the Inverter. Amazing amount of surface area in that little box. Quite some engineering. But alot to corrode also.
    It behooves an owner to keep very high quality coolant in the Inverter loop.
    Dino33ca and frodoz737 like this.
  17. frodoz737
    4,734
    2,526
    33
    ...and fresh coolant. Respectfully, waiting for signs of of rust and sediment before servicing means you waited to long.
  18. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
  19. edthefox5
    10,096
    4,835
    Clearwater, Florida
  20. edthefox5
    10,096
    4,835
    Clearwater, Florida
    I know you hate reading all the threads before you make a comment but please make an exception and read post #12.
