mileage
Discussion in 'Gen 2 Prius Main Forum' started by jloretta, Feb 9, 2006.
  1. jloretta
    jloretta Junior Member
    17
    no steep hills...flat roads of New Jersey...maybe it needs to break in???
  2. aaf709
    3,862
    2022 Prius Prime
    Part of it is break in, both the car and the driver. I did worse when my commute was only 5 miles each way. Now it's 18 miles of freeway, residential and hills.
  3. rogerSC
    rogerSC Member
    170
    One of the key things is to batch together your errands. If you make a lot of short trips, there's no way that you can get great gas mileage. The car has to get warmed up pretty well to get good gas mileage. My old commute was about 10 miles each way mixed freeway and arterial, and that was enough to get the car warmed up, I was getting about 50mpg even at that distance. Now that I'm not commuting and taking shorter trips, my gas mileage is more variable, 41+, but not the 50mpg that I used to get.
    On the other hand, I still end up using less gas than I was.
    -Roger
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Not sure what city you live in, but the state probably explains it. I just looked up the temps in Middletown, NJ (http://weather.yahoo.com/forecast/USNJ0308.html) and it looks like the highs are in the high 30s and lows are in the 20s.
    Cold weather hurts fuel economy of all cars.
  5. jloretta
    17
    thanks
  6. jloretta
    17
    thanks
  7. jloretta
    17
    thanks...Pitman,NJ
  8. jloretta
    17
    thanks
  9. MyPria
    MyPria New Member
    70
    Colorful Colorado
    Did you break the car in by driving and breaking nice and easy the first 600 miles as the manual says to do? I live in hill and cold country and am averaging around 50mpg. I've just passed the 1000k mark and I'm still driving her nice and easy.
  10. jloretta
    17
    yes....
