  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Cool. Now you don't have to worry about looking like a Christmas tree.
  2. kmkremer
    kmkremer Member
    227
    30
    San Diego
    They don't have reflectors on the side so they do not meet code.
  3. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Technically true, but taillights aren't required to have side reflectors as long as they're somewhere on the body of the car and many manufacturers do that.
    You can stick reflectors on the sides of the bumper to be within code but I wouldn't bother given that none of the 100 plus PC members with aftermarket taillights have ever been pulled over for lack of side reflectors. It's enforced even less than illegal tint.
  4. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    I'd be interested in seeing how the plastidip holds up on the brake calipers. Those get damn hot.
    You'd be better off using engine enamel for calipers.
  5. goliath1812
    goliath1812 Member
    Florida, USA
    I
    Plastidip has a temp rating up to 312 degrees. I also dont plan on driving this thing like a sports car, I try to use as much regen braking as possible, and keep the friction brakes to a minimum. Time will tell as to how they hold up. I wanted Plastidip just for the ease of removal if I ever want to.
  6. Burntdough177
    Burntdough177 Junior Member
    25
    Northern California
    do you know of anyone who has been pulled over for that?
  7. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    No PC members have ever been pulled over specifically for lack of side reflectors. One member (Ragz) did get cited for too dark taillights in N.Y. but got it dismissed. Another member, ucsmfu in Canada, got a warning because Canadian police for some reason thought there weren't any rear reflectors on his Valenti SB taillights, which isn't true as they do have fully exposed rear reflectors.
    Burntdough177 likes this.
  8. Burna J
    1,070
    3,339
    53
    Long Beach, CA.
    Thanks Bino, They're about 5" wide to give them strength. And they fit real nice, with a slight taper front and rear. I pick them up from Alex at Fuzion Teknique. ( 310-408-0724 ) They have them in stock right now for 350 + installation.
    bino likes this.
  9. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Installed the JDM piano black shift knob today to match my JDM piano black steering wheel. While nice looking, I couldn't bring myself to get one of the electronic shifters as I don't like the idea of not being able to shift intuitively under duress (in an emergency situation) so I went big instead. Yes, it has the JDM shift pattern so it's the other handedness just like JDM electronic shifters.
    FishCandy, sfv41901, Burna J and 3 others like this.
  10. U2NVME64
    U2NVME64 Junior Member
    77
    25
    Looks awesome, how much we're the Valenti's? And how long did it take to get them?
  11. xcuter
    xcuter Active Member
    303
    182
    Nice where did you get that from?
    SPH-L900 ? 2
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Are you asking about the Valenti lights or JDM shift knob or ?????
  13. xcuter
    303
    182
    Sorry the shift knob
    SPH-L900 ? 2
  14. U2NVME64
    77
    25
    I washed my baby on Friday and detailed it. So happy that it rained the next morning.
    jesseboy661 likes this.
  15. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    how about this?
    SoCal: West Covina Lunch meet???? Aug 17 | PriusChat
  16. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I got it from the ebayer zeroism702 2009 2010 2011 2012 2013 Toyota Prius ZVW 30 35 Leather Shift Knob Black | eBay
    I actually had a smooth leather version that I got through Nigel a couple weeks ago for only $40, but I wasn't satisfied with the build quality of it. Nigel said the factory doesn't make the perforated leather version anymore but it was dirt cheap at $40 so I got it anyway to see if I like it.
    Below is a pic of the two. $99 one on the left and $40 one on the right. The $99 one has much tighter stitching in black vs. the gray stitching with some frayed ends on the $40 one. They're obviously made by different factories. If you already have the JDM piano black steering wheel, then definitely get the more expensive one as it's perforated and its stitching is more similar to that found on the steering wheel. Otherwise, you may not care.
  17. burstaneurysm
    469
    144
    Chicago, IL
    Supposedly, it's a $500 fine in Illinois to run without reflectors. That being said, my xB didn't have front or rear reflectors for several years. I never had a problem and I don't know of a single person who was ever cited for it.
  18. chinito77
    chinito77 Member
    84
    35
    Yamaguchi, Japan
    goliath1812, loving the wheels and brakes! Where and how much for the calipers? How much improvement over the stock ones?
  19. goliath1812
    goliath1812 Member
    Florida, USA
    I
    Thanks Chinito, they are stock calipers, painted with Plasti Dip.
  20. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Built a board for the lower part of floating bridge console so I don't do UFC on the upper part.. fun stuff :rolleyes:
