Plus Springs.. are Sway bars needed??
Discussion in 'Gen 3 Prius Main Forum' started by Burntdough177, Jul 21, 2013.
  1. Burntdough177
    Burntdough177 Junior Member
    25
    Northern California
    Im thinking of getting the Prius Plus springs and rear sway bar. I was wondering if the Sway bar is needed if i purchase the springs.
    Can i install the springs without getting the rear sway bar? Will this cause any damage or wear down the road. Are they meant to be put on at the same time.
    thanks.
  2. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    Sway bar is not needed, but it would be a nice little add on. After you lower it a alignment check would be nice to add.
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    I think you meant required? Not required with Plus springs. Def. no damage without it. Improvements are quite noticeable to me without it.
  4. Burntdough177
    25
    Northern California
    have u had them on before?
  5. xliderider
    xliderider Senior Member
    8,083
    3,236
    Honolulu, HI
    Yes, but give it some time to settle in before getting the alignment done.
    SCH-I535
  6. Burntdough177
    25
    Northern California
    are u saying install the springs and run on them for a while.... then get the alignment?
  7. xliderider
    8,083
    3,236
    Honolulu, HI
    Yes.
    SCH-I535
  8. Burntdough177
    25
    Northern California
    at the risk of sounding like a noob . . . how long am i going to hold out before i get an alignment? or how many miles.
  9. xliderider
    8,083
    3,236
    Honolulu, HI
    Depends, how many miles do you drive per week/month? Maybe one tank full.
    SCH-I535
  10. Sfcyclist
    1,621
    375
    SF, CA
    Have Plus springs or sway bar. I have the springs no sway bar thus my comment.
  11. Sfcyclist
    1,621
    375
    SF, CA
    I drove much longer, about 3k miles, before alignment. And even when they checked it, only the front toe was out very slightly. The rear was toe was out just as much but they don't adjust or shim the rear. This was at the Toyota dealer too.
