Gen2 Prius: Custom PIDs for Torque (Android App) with formulas
Discussion in 'Gen 2 Prius Technical Discussion' started by usbseawolf2000, Jun 24, 2011.
  1. paulcummings55
    paulcummings55 Junior Member
    Austin, TX
    Let me ask this then- is there a compilation of the Torque logs from other 2nd Gen Prius owners (specifically 2007), preferably with normal running Prii, with which I can compare my own logs? Using such other logs would enable me to perhaps see what is a 'good' baseline compared with ours, and shortcut trying to interpret them.
  2. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Well, I have a new android phone now that cost $50 from Amazon that plays nice with a $10 elm327 bluetooth ODB adapter and has a 3.5" screen so I didn't ever bother with the USB connection.
    Nice thing is the bluetooth ODB works with the old Saturn SL2 as well so I'll be getting MPG data from it in a few days.
  3. justin12
    justin12 New Member
    Hi folks,
    is there a PID to change hv fan speed manually in a 2006 Prius Gen.II?
  4. justin12
    justin12 New Member
  5. justin12
    justin12 New Member
    I tried it this way but i dont know how to modify ModeAndPID correctly. These where my steps:
    ->Settings ->Manage extra PIDs/Sensors ->Press menu button "add custom PID" and then fill in the above values -> Press "OK"
    The following Message accours: "PID is too long - can be 3 bytes (6 hex characters) only"
    Maybe i am totally wrong and i dont have to add a custom PID for a send button? If i try it this way ->add display -> select type of display "push button" (last entry) -> send OBD command -> display configuration ->set command to send i dont know what to fill in there correctly. Please help me. Thank you.
    Best regards
    Michel
  6. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Yeah, I couldn't figure it out either.
    LG-AS695 ? 2
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Guys, try these below. I shortened them to 3 bytes, not sure if they'll work.
    ->Settings ->Manage extra PIDs/Sensors ->Press menu button "add custom PID" and then fill in the values -> Press "TEST"
    If they don't work, we'll have to ask Ian to re-add 4 bytes (8 Hex chars). Previous version of Torque allowed 4 bytes before.
    Column 1
    0 [TH]Name[/TH][TH]ShortName[/TH][TH]ModeAndPID[/TH][TH]Equation[/TH][TH]Min Value[/TH][TH]Max Value[/TH][TH]Units[/TH][TH]Header[/TH][TR][TD]Set Battery Cooling Fan Speed 0 (Off)[/TD][TD1]SFS0[/TD1][TD1]308100[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR][TR][TD]Set Battery Cooling Fan Speed 1[/TD][TD1]SFS1[/TD1][TD1]308101[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR][TR][TD]Set Battery Cooling Fan Speed 2[/TD][TD1]SFS2[/TD1][TD1]308102[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR][TR][TD]Set Battery Cooling Fan Speed 3[/TD][TD1]SFS3[/TD1][TD1]308103[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR][TR][TD]Set Battery Cooling Fan Speed 4[/TD][TD1]SFS4[/TD1][TD1]308104[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR][TR][TD]Set Battery Cooling Fan Speed 5[/TD][TD1]SFS5[/TD1][TD1]308105[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR][TR][TD]Set Battery Cooling Fan Speed 6 (Max)[/TD][TD1]SFS6[/TD1][TD1]308106[/TD1][TD1]A[/TD1][TD1]0[/TD1][TD1]6[/TD1][TD1]No reply required[/TD1][TD1]7E3[/TD1][/TR]
  8. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Thanks usbseawolf2000 :) I can't wait to try these after work.
    LG-AS695 ? 2
  9. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    LG-AS695 ? 2
  10. justin12
    justin12 New Member
    Wow thank you for your fast reply. I checked it and the fan speed did not change. for a second a message pops up. i cant remember what info was displayed in detail. something like: no response. equation 0.0 Any ideas what to change?
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Then, ModeAndPID needs to be 4 bytes (8 chars). We'll need a new version of Torque app. You can request this feature (removal of limitation) on the Torque forum and the author (Ian) can reimplement it. Not sure why he limited to 3 bytes. It used to allow 4 bytes.
    Edit: I posted a request on Torque forum.
    ModeAndPID
    30810000
    30810001
    30810002
    30810003
    30810004
    30810005
    30810006
  12. justin12
    justin12 New Member
    Thank you especially for your request. Hope Ian will remove the limitation
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Anyone get this to work yet?
  14. dni
    dni New Member
    could you change the Faranheit temperature units to celsius in the USBSeawolf2000 Gen2 Prius 1-11-12 (Metric) csv, or would you so kind to explain, how can i do that?
    Thanks for your reply.
    lopezjm2001 likes this.
  15. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Let's take an e.g.
    MG1 Inv Temp (F) = 1.8 * Y - 58
    To convert to C, we know
    C = 5/9 * (F - 32)
    By substitude F = 1.8 * Y - 58,
    C = 5/9 * ((1.8 * Y - 58) - 32)
    C = Y - 50
    MG1 Inv Temp (C) = Y - 50
    For Battery Temp., you can check my post #56.
    Vincent
    mrbigh and lopezjm2001 like this.
  16. Rick Lundh
    Rick Lundh New Member
    I am trying to see if there is a way that I can display the gear position in my GenII, hopefully in the Torque Pro app. I see your list here includes Shift Sensor Shift Position | Shift position P, R, N, D or B and I am not sure if you have it display in your vehicle..and if so, how?
    Thanks!
  17. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    Is there any reason to prefer PLX Bluetooth over PLX WiFi?
  18. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    Wifi will give you a lot more updates per second. I haven't used one, but I wish I had one.
  19. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Is there a Torque application for the Ipad. Maybe someone could write the Torque application for an Ipad.
  20. mfa-prius
    299
    46
    Hansville, WA
    I have a vague remebrance of someone mentioning that the PLX WiFi adapters use Ad Hoc wireless mode, and Androids don't support that.
    PLX's web site clearly states that their WiFi products are for iOS devices, and their Bluetooth products are for Androids. Very disappointing. I think you could root your Android device and make it work, but it's probably not worth it. This may be the excuse I'm looking for to buy an iPad.
