PIP & MPG Spreadsheet
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Apr 5, 2012.
  1. bisco
    52,284
    ken, someone screwed up the table can you please resort alphabetically? thanks!
  2. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Done.
    I asked Google to Block anyone not logged in and using Anonymous from modifying the MPG Sheet.
  3. bisco
    52,284
    wonderful, thank you. although, i'm not too happy about 34hupp taking first place. and he's a gas hog too!:p
  4. bisco
    52,284
    hi ken! can you move my data please? thanks!
  5. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Ukr did you get my June 22 data? Computer died shortly after so I'm not sure if it took.
    iPad ? HD
  6. JimPHL
    JimPHL Member
    74
    33
    Cinnaminson, NJ
    Pretty crappy EV mileage, which is typical of my low EV% tanks. I am wondering if we are on the wrong side of the warmth that the battery loves; 90 degrees F for past couple weeks in NJ. Also, I think my estimate of 15% charge loss from the wall to the battery may be conservative, but a Kill-a-Watt meter really isn't something I am that interested in playing with. I also notice when I have a lot of highway miles, I don't do as well on the EV mileage. Any ideas here?
    The cost per mile in HV mode was impacted by the price of gas, which was $3.56/gallon. Not a lot compared to most regions, but a spike of nearly 10%.
    Enough griping. It is a fantastic car and I'm loving it. Trying to figure out the variables that impact EV and HV mileage is fascinating. I'm sure I am in good company :)
  7. bisco
    52,284
    agreed on the temps, i think 70-85 is the sweet spot, and humididity may play a part in higher a/c requirement, thus heavier load on battery.
    markabele likes this.
  8. stacey
    stacey ☆☆☆☆☆
    115
    Lancaster, PA
    Looks like anonymous made a change yesterday (adding a link to Craigslist) on the first sheet. I restored the document to the previous update you made, since no one else had made any modifications since that time.
  9. bisco
    52,284
  10. lensovet
    2,615
    496
    Burlington, NJ
    just added my stats! last tank lasted almost 1k miles!
  11. bisco
    52,284
    shaweeeeet!!!:D
    lensovet likes this.
  12. JimPHL
    JimPHL Member
    74
    33
    Cinnaminson, NJ
    Gang, for what its worth, I'm putting down the pen on tracking mileage on my PIP. I am applying the 80:20 rule to my learning curve. Through diligently tracking the numbers for the last nine plus months, I believe that I I've been exposed to and understand the most influential variables that impact MPG in the PIP, at least as they apply to my commute, lifestyle, etc. And, I firmly believe that another year of tracking will only yield a bunch of 'been there, done that' postings in this forum, and I don't want to waste space or your time. But, if I discover something that I believe the group can benefit from, I will gladly share it here. Happy motoring.
  13. bisco
    52,284
    thanks jim, all the best!(y)
  14. bisco
    52,284
    ken! can you move my info please? thank you!!!
  15. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    blift and
    Gizmoz,
    Thanks for using the Spreadsheet, but can you add the fillup numbers from your HV and EV displays?
  16. bisco
    52,284
    hi ken, please add my data, thank you!(y)
  17. davekro
    davekro Active Member
    527
    79
    SF Bay Area, East Bay
    2013 Prius Plug-in
    What do you use the spread sheet for? Is open to anyone?
    If so, how do I sign up for it?
    Thanks (new PIP owner :eek:)
  18. bisco
    52,284
    yes, it's open to anyone. i use it to track my stats and compare to others. there is an 'add' tab to put your numbers in, and then, ken, (ukr2) has to move it into the spreadsheet with all the others.
  19. davekro
    527
    79
    2013 Prius Plug-in
    But I must need to sign up for access because when I open it I see only one page of a spread sheet. And Ken mentioned in posts about now having a sign in so anonymous could not mess with it.
    ANyone have a pointer to signing up?
  20. bisco
    52,284
    i didn't sign up, but perhaps he's changed it. he might mean not logged into priuschat, i don't know. are you looking at it from a computer or mobile device?
