New shift knob
Discussion in 'Prius c Accessories and Modifications' started by tk1971, Jul 23, 2013.
  1. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    Made a new shift knob.
  2. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Pretty nifty.
  3. firstrival
    firstrival Member
    102
    Looks like the one from an IS 300.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    great knob. ;)
  5. xliderider
    xliderider Senior Member
    8,126
    3,266
    Honolulu, HI
    Just don't go around asking people if they'd like to polish your knob. :D
    SCH-I535
    type17volkswagen likes this.
  6. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    Too bad C's are shiftless. Self made, I'm impressed, very neat.
  7. tk1971
    253
    133
    SG Valley, CA
    Firstrival: Yep, I miss the nicely polished ball from my IS300, so I came up with this for both the C and the CT.
    Yeah, I miss driving a manual too.
    Well, I'm not taking all the credit as I didn't cast and cnc each ball. They're basically large / pricey cabinet knobs with a standard 1/4" thread. I made a jig to hold the balls without scratching them so I can re-drill and re-tap them to M8x1.25. In order to cover up all of the screw threads on the car's shifter shaft, I had to re-drill them way deeper than how they came, and I had to use both a tapered tap and a blind hole tap. They then go through a final polish with a polishing cloth. As far as being a perfect sphere is concerned, they're not (but close enough), so there are imperfections in the shape if you look closely for them.
    Because of the potential screw-up factor and high cost of shipping (in case I had to buy more if I screw up), I actually got a few of each in both brass and aluminum. As it turned out, the project was easier than I had thought, so I have a few to play around with and slapped one on the C.
    Here is a brass one in my CT200h:
    I was going to artificially age one of the brass knobs with Liver of Sulphur to see if I can get an old steam-punk look from it.
    Since the brass ball weighs so much more than the aluminum one, I may put one on the C, but I suspect it may clash with the interior. I'm now thinking a heavily patina'ed brass knob would look good in the C.
  8. B2FiNiTY
    979
    227
    the brass one looks cooler. definitely go with a patina'ed look!
  9. tk1971
    253
    133
    SG Valley, CA
    The shift knob aged well with the liver of sulphur treatment. Got some interesting brown, gold, blue and red hues.
    The wife likes the patina'ed look in the C:
    xliderider likes this.
