Prius won't go into gear on 1st start.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by alrdye, Jul 23, 2013.
  1. alrdye
    alrdye New Member
    I just purchased a 2008 Prius C Touring edition from CarMax. I have an appointment to bring it back but this may be a user error issue. My issue is that when I first hit the Power button the indicator light on the button goes green. When I hit it a 2nd time the light goes orange but stays on. When I shift to R or D it will shift to N but no further. I do have my foot on the break but the only way I can shift into R or D is to hit the power button twice more, to turn it off and back on. When it turns on the 2nd time, the indicator light on the Power button goes off.
    Am I doing something wrong?
    Thanks.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the proper forum (gen II) and sub forum
  3. Patrick Wong
    18,204
    6,505
    Press hard on the brake pedal as you depress the POWER button. Also, rather than "hit" the button, hold it down for a second.
    If you still have trouble making the Prius READY, the brake pedal switch may need to be adjusted.
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It's not clear from your description if you're pressing the brake pedal while pressing the power button.
    Pressing the power button twice without pressing the brake puts you in an in-between state called "On" rather than "Ready".
    As stated above, press and hold the brake pedal while pressing the power button. You'll only have to press the button once to go into Ready mode.
  5. alrdye
    alrdye New Member
    Ahh, yes, I am not pressing the break while pressing the power button, only when attempting to put it into gear. I'll give that a shot. Many thanks!
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Your pressing the power button twice. Twice your in accessory mode. Only press the power button once with authority while holding the brake in. That puts the car in ready.
    The car will not go into gear until it says READY in blue letters in the dashboard right to the right of the speedo.
    That means the car has essentially started and it ready willing and able to motor on down the road.
    Then the car will not go into D unless your foot is on the brake also. Safety.
    With brake on push button car goes into ready. Then get yourself set up....belt..ac..radio.
    When ready to go push brake down again and shift into D.
    Give the owners manual a good read. There's a few gotcha's with this car.
  7. alrdye
    alrdye New Member
    Issue resolved: I did hold the break while powering it on and that did the trick. Thank you everyone for your help!
