I avg 38mpg on my 2005 prius.
Discussion in 'Gen 2 Prius Fuel Economy' started by Saithus, Jul 24, 2013.
  1. Saithus
    Saithus Junior Member
    17
    I'm avg 38mpg on my 2005 prius. It seem like it drives fine...its at 99000 miles right now. The battery is fine. I'm due for an oil change in 3000 miles. Should I get synthetic? Would that help? Any advice?
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    How do you know the battery is fine? What are the voltage readings after sitting up for some hours, like overnight?
  3. Saithus
    17
    I went into diagnostic mode and turn the car on and it kept a good charge like 14v consistently.
  4. Saithus
    17
    I don't know... I don't have much money and I just wanna make sure the thing doesn't quit on me one day. lol
  5. SteveLee
    645
    180
    North Carolina
    I
  6. Saithus
    17
    I checked the voltage after the car sat all night. The battery stayed at 14v. So I don't think its the battery. The car does idle sometimes...not much tho... during hwy speeds its pretty good nothing bad. during slow speeds it seems kinda rocky. I don't know.
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    The 14V is only telling you that the charging system is working.
    As SteveLee posted above, please report all three values, not just the last one.
    DO-IT-YOURSELF TEST PROCEDURE (thanks to jdenenberg):
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    What we are wanting to know is the ACC mode reading, the ign on reading, and finally the ready mode reading. Follow the steps above and report back with all three readings.
    Example: Acc Mode: 12.6 volts
    Ign. On Mode: 12.4 volts
    Ready Mode: 14.0 volts
    Ron
  8. SteveLee
    645
    180
    North Carolina
    I
    Get the voltage values with this on-board method and report all three values back here so others can help you determine if the 12v is weak. I believe your 14 volts is the charging voltage. It's good that it's charging but that is not telling you everything you need to know.
  9. dorunron
    3,318
    1,103
    Houston, TX
    Saithus,
    It might be a good idea for you to read the following link. Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat Then copy and paste the questionnaire into the post you started here. With the info from the questionnaire, we may be able to pinpoint if you have a problem or not.
    YMMV
    Ron
  10. Saithus
    17
    ACC Mode: 12
    ign on mode 11.8
    Ready mode: 13.8 - 14.0
    Well what you guys think?
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    For a working vehicle in near constant service what you are asking for here is almost an impossibility.
    All modern vehicles are complicated machines, The Prius probably more so than most. Therefore for all of us, there is always the constant risk of it quitting on you one day.
    Significant investment into maintenance reduces that risk, but for an aging vehicle being used as a daily driver there is no way to totally divorce oneself from the risk of an unforeseen failure.
    The catch 22, is nobody wants a high repair bill, but if you are saving money, or on a budget than often maintenance costs can be prohibitive as well.
    That's one thing I enjoyed about owning some of my older small pick-ups. They were primitive in both safety features and amenities by todays vehicles standards, BUT...they were relatively simple machines. What could go wrong with them was very obvious. Engine, Transmission and maybe suspension...but there wasn't a whole lot else to worry about. Keep up with brake pad and clutch...and routine fluid replacement and they were bullets of reliability.
  12. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I suggest a spark plug change. Brought our GenII's mileage back up to mid 40's.
  13. SteveLee
    645
    180
    North Carolina
    I
    Have you driven it today? These numbers are a little weak but not terrible. Has it been charged today? I would consider filling out the questionaire now like dorunron suggested. The more info we have the better we can help.
  14. dorunron
    3,318
    1,103
    Houston, TX
    As SteveLee suggested, please fill out the questionnaire. It will help immensely in your case. FWIW, your 12 volt is reading weak. What that means is that it is not FULLY charged. The 12 volt may last through the summer and fail during the winter, or it may last a couple more years. However, until you fill out the questionnaire we can only guess as to what the problem or problems is.
    Ron
  15. SteveLee
    645
    180
    North Carolina
    I
    Yeah, actually 12v represents about a 50% state of charge for this battery. If it will not hold a charge it needs to be replaced when you can. A trickle charge may be an option but I think the general experience is that when they start going south they don't revive. At this point it could start causing weird electrical issues and loss of mpg (oops, already have that) and even put you down at the least convenient time. Better to replace it on your schedule instead of being forced into it. Gives you time to do some research for a replacement.
  16. Saithus
    17
    Ill fill out the questionnaire
  17. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Synthetic oil of the same grade will have negligible effect on your fuel economy. That said however, it's still worthwhile using a good quality oil.
    BTW. What is your oil change interval? (miles/months).
  18. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    Soooo....whens the last time you checked/adjusted your tire pressure?
  19. Saithus
    17
    - Have you read This Thead Yet? No
    - What fuel economy are you getting and how are you determining fuel economy?
    I base it on the screen...it ususally says between 36mpg and 38 mpg
    - What fuel economy are you expecting and why? I'm expecting at least 42MPG to 47MPG
    - What are the approximate outside air temps? 90 degrees plus high high humidity.
    - How long are your trips? Between 12 and 18 miles on average.
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving? Mostly city. And sometimes a lot of stop and go. And most of the time its not.
    - What region/state are you in? Mississippi
    - What's the terrain like of your drives? Flat roads
    - Is your oil overfilled? No its not. Its right on the mark
    How old is your 12v battery? I don't know. And its readings are above this post.
    Have you had your alignment checked? No alignment check, and it pulls to the right.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size 185 16 15. And they are touring integerity.
    - What are your tire pressures? Need to check.
    - Make, model, year, engine and transmission of previous car? 2010 Mazda 3. 4 cyclinder
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking? I brake normally. Sometimes hard. I try not to press the gas so much.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on? Nope, I gotta get going.
    - Are you driving using D or B mode? D
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to? I use the AC and its almost all the time on full blast and max cold. Mostly due to my gf. I've changed this when she's not here and it gives it a slight mpg boost when not even using the AC.
  20. SteveLee
    645
    180
    North Carolina
    I
    Your MPG expectations are reasonable. The 12V is weak and requires the engine to run more. Front end pulling, out of alignment causing more drag, makes the system work harder. Integrity tires have the best dry road stopping and cornering numbers but the worst on wet roads of a half dozen brands and is a couple of MPG's less than the Michelin ES and the Bridgestone Ecopias.
    You're losing MPG by not taking advantage of the regenerative braking. The HV battery has to be continually recharged. The less regen braking is allowed to work, the more the engine has to run to charge it. Anticipating stops and slowing conditions far ahead by letting off the accelerator, coasting more, and then slight brake pressure allows the regen braking to recapture energy already purchased, saves on brake repair/replacement, and increases MPG.
    It does take a little adjustment in driving patterns to take advantage of the efficiency of the car. It looks like the culprits are partially mechanical and partially driving style.
    Saithus likes this.
