70mph freeway
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 510bg, Jul 23, 2013.
  1. 510bg
    510bg Member
    142
    This seems like my issue.ill get to 70mph lift my foot off the pedal and the seems to dip to 65 before I know it. No lead foot here.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Wonder if the shifter is in B mode.
    Should be in D
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Stop driving binary style! Modulate pedal pressure to maintain speed. Don't jam the pedal then take off then on then off then on. Apply foot, press down and keep pressed down at the same pressure that makes you go the speed you want.
  4. 510bg
    510bg Member
    142
    Ill have to test this and report back. I noticed this could be something that could be done. Driving in B mode and not even noticed
    JMD likes this.
  5. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Hate it when I realize I am driving in B mode. ICE is still running when you stop at red lights. I avoid B at all costs.
  6. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Yes, our miles are shorter too. And our hours are slightly longer... ;-)
    Back to the OP, what took me time to get right was that slight pressure on the accelerator that moves the electric ... thingy .... from generator to either nothing or just a little motor. Taking your foot off the pedal altogether is the equivalent of gentle braking in a normal car.
