Air pressure for v Five
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by bikeboy999, Jul 19, 2013.
  1. bikeboy999
    bikeboy999 Junior Member
    43
    Ottawa, Ont.
    2015 Prius v wagon
    Hello, I did try a quick search to find out specifically what people are running on their v's. I just put my pressure up from 30psi all around to what I thought was 38 and 34. But I just ran out and bought a Topeak D2 bicycle guage to get a digital readout. And by the time I got back from bike store, temp 90s tires are registering in mid to low 40s. So I will check them tomorrow in the early AM. When they will be cold. But what are people finding is best for comfort and mpg.
    Brian
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Comfort is a relative term on low profile tires, they are all hard as a rock regardless of pressure. I'd suggest going with 5 lb over the recommended pressure on the door post. FWIW, I'm old school and distrust digital gauges. I still use an ancient Accu-Gage, must be 30 years old but it was quality at the time and still is. One good test of a gauge is to repeatedly check the same tire and see what kind of variation you get.
  3. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    I'm at 50 psi now. 10 psi over max sidewall. Going for best mpg possible. Ride comfort hasn't really changed a great deal from max sidewall, maybe you feel the bigger bumps in the road a tiny bit more.
  4. wstt
    wstt Member
    147
    You're running 50lbs which is 10lbs over the max sidewall? The max on your tire sidewall says 40psi? That seems really low, what tires do you have? I have the Toyo, my sidewall says 51lbs max and I'm running 40lbs in the front and 39 in the rear and getting 45mpg. The ride feels stiffer which I like because when I cornered harder at the recommended tire pressure, the tire felt way too soft.
  5. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    I know, I thought the same thing. they are yokohama s34b. I'm averaging 52 according to fuelly.
  6. AtoyotA
    AtoyotA Junior Member
    Chicago area
    I have a Prius v Five and run the Toyo Proxes at 42 front, 40 rear. Definitely a firm ride but I like it that way. Have never tried going higher so don't know how that would feel.
  7. crpriusv
    crpriusv Junior Member
    43
    Delaware
    I think you're asking for trouble if you're 10 psi over the sidewall limit. You're setting yourself up for a blowout, especially if you drive much on beat-up roads (NYC). Not to mention that excessive tire pressure will lead to more wear and tear on the suspension and steering linkage .
  8. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    Honestly I really doubt 10 psi will cause a blowout... I wont go over that but 50 psi is not much...some people go up to 75 or 80.
