Random scuff marks on plastic interior..
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TheyCmeNow, Jul 26, 2013.
  1. TheyCmeNow
    TheyCmeNow Junior Member
    77
    25
    Doesn't the plastic interior seem too easy to scuff? I take good care of my c but almost all the plastic panels are scuffed up. The driver's door panel, passenger's glovebox, and door sills love to scuff up. I tried wiping the scuffs with a rag and water but it only helped so much..
    Have any of you experienced such problem? How do I clean such fugly marks?
    Help is appreciated :)
      File size:
      57.2 KB
      552
  2. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    got 'em too!
  3. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Hmmm this is another thing I've used ArmorAll Protectant on happily. I've always assumed I'd get the same results from wet rags, minus the pleasant scent.
  4. TheyCmeNow
    77
    25
    I happened to drive by my local walmart and decided to pick up some AmoraAll.
  5. HotDogWater
    HotDogWater Junior Member
    70
    17
    yep, just noticed this today by the audio/USB connection
  6. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    The only place I've found scuffs I can't remove is on the center armrest (from dogs' nails).
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I get my worst ones on the inside of the door pocket...
    PPLMTD#500 likes this.
  8. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Ditto.
  9. wmo168
    wmo168 Member
    239
    South Florida
    ArmorAll will hide it well.
  10. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Prius interiors are finicky sadly, I have noticed a few random ones in both Prii.... I use either a lightly damp cloth or I use this with a micro fiber towel.... remove the tag as the tag on the towel I've found leaves marks too...
  11. orenji
    orenji Senior Member
    5,887
    3,488
    Door sills got them, and I try so hard no to make them when i enter and exit the car. May just may order an extra door sill to replace the original when it gets too bad.
