CD Player does not display any title or track info
Discussion in 'Gen 2 Prius Audio and Electronics' started by nevets2, Feb 12, 2006.
  1. nevets2
    nevets2 Junior Member
    I have a 3 month old Prius 2005 - fully loaded. The 6 disc CD Player works fine, from an audio perspective. But it has never displayed the title or track info for the CD's it is playing. SO far I'm only playing "store-bought" cd's that work fine giving off title and track info to other CD players.
    What's wrong with the Prius CD Player?
    Can I fix it or must I return it to the dealer?
    http://priuschat.com/style_images/1/folder...icons/icon9.gif
  2. Tideland Prius
    16,615
    Ever thought it might be the CDs that you're playing? If the CDs don't have CD-TEXT in the disc, then how can the Prius' CD player display the artist/title?
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i heard there are only certain programs you can use to burn a cd that works for the car. It won't read all ct text.. i think it has to be nero or something... *shrug*.. never liked nero.. never had text show up.. corrilation there?
  4. DaveG
    DaveG Member
    806
    Vancouver, BC
    Are the other CD players network connected?
    I've found that very few store-bought CDs don't have CD-Text embedded on them (do not know why, seems like they should, but I suppose there are very few CD players that actually support text of any sort anyway).
    Burn your own CDs with compatible writing software and you can add the text in yourself.
    Dave
  5. thejq
    thejq Junior Member
    34
    I've used Nero with success. Make sure to use the newer version and turn on the CD-text. If confgured properly, Nero will get the CD info automatically from the internet.
  6. castlecain
    castlecain Junior Member
    46
    North Carolina
    Try the Dixie Chicks "Home" CD. It displays song and
    artist info. I could not find a CD which would display, and
    got a tip to try that one. Works. Check your system with it.
    Rod
  7. dgstan
    dgstan Member
    159
    OC
    Matisyahu's "Live at Stubbs" has the text embedded as well. I don't see too many "store bought" CDs that include the info.
    Quite often, when I get a new CD, I'll use CDex to look up the track info on CDDB. I then rip it to WAV and re-burn it with the song titles enabled.
  8. Mike_V
    Mike_V New Member
    New Orleans, LA
    I've been disappointed by this problem as well. I normally use Roxio Easy Media Creator to burn CD's. I just tried burning one using Nero, and sure enough, it worked!
