Ford Finds 60 Percent of Plug-in Vehicle Trips Are Gas-Free
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Electric Charge, Jul 29, 2013.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    austingreen likes this.
    52,405
    doesn't surprise me, but keep in mind, people considering phev's take the potential ev usage as part of the decision process.
  3. Electric Charge
    545
    133
    Syracuse, NY
    That's the thing, many people, including myself, underestimated how much impact the 'low' EV range has. I averaged between 80 and 100 MPG for my commute (without recharging at the office), and with proper driving, local trips were very close to being pure EV.
    My main point of this post was to show the folks who insist the PHEV just can't make financial sense, that it does make sense/cents in many scenarios.
    JMD likes this.
  4. Species5618w
    Species5618w Member
    140
    90MPG is 2.6L/100km. I average 3.6L/100km commuting locally in my Prius C. That's 1L/100km, or about $300 a year with 20,000km driven, assuming no long trips.
  5. bisco
    52,405
    but a much smaller car, so tough to compare. now, if there were a prius c plug in...
  6. Trollbait
    12,690
    Plug In Supply has a conversion kit for the c.
  7. bisco
    52,405
    but nobody's ever done one.;) if they di, there'd be no payback ever.:rolleyes:
    JimPHL likes this.
  8. austingreen
    austingreen Senior Member
    13,703
    4,229
    Austin, TX, USA
    I can't see anyone really wanting to do a prius c conversion, when you can do a conversion of a used gen II prius, and not worry as much about voiding your waranty. With the discounts and tax credits on prius phv, energis, volts, and leafs, I don't think there is much of a reason for a prius c plug-in.
    JimPHL likes this.
  9. bisco
    52,405
    well, there's a reason, but it doesn't justify the cost. especially with a system that's hit or miss at best.
  10. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    At least you estimated. Lots of people instantly dismiss, without giving a moment of consideration.
    I recharge at the office. 46 miles of driving today. The result was 112 MPG.
    How many people would has estimated that as the outcome?
  11. Electric Charge
    545
    133
    Syracuse, NY
    Yep, forgot to mention that my commute is 42 miles, no recharging at the office, and plenty of hilly areas.
  12. Species5618w
    Species5618w Member
    140
    42 miles x 250 working days = 10500 miles. At 90 MPG, that's 116 gallon. If a Prius gets 51 MPG, that's 206 gallon. At $4/gallon, that's $360 differences.
    In John's case, 46 miles x 250 working days = 11500 miles. At 112 MPG, that's 102 gallon. At $4/gallon, that's $416 differences.
    That's assume the Prius can't achieve higher MPG, which it certainly can.
    A plugin is much quieter and more smooth than a Prius. I think it makes perfect sense for some people to get it. I am just not sure it makes financial sense without taxpayer subsidies even for extreme cases like yours.
  13. Electric Charge
    545
    133
    Syracuse, NY
    I wouldn't call my case 'extreme'. Extreme are the folks who live within EV range. And if I charged at work, my numbers would have been much higher (but I still would not considere it extreme).
  14. 3PriusMike
    3,101
    2,419
    Silicon Valley
    My commute is only 6 miles each way. (2 days per week a couple of miles more to the gym). I charge at work. I wouldn't call this extreme. If I lived ~6 miles further away I could still drive in EV only all week, by charging at home and at work.
    After one year I am at 9400 miles, ~60% is EV. I consider extreme, people who drive 20K or 25K miles per year. Historically, the Prius has appealed to those who drive lots of miles, because the high mpg gives lots of savings. But the average miles per year is 12-15K. So for every driver who goes 20K miles, there is one who drives only 8K - 10K.
    Mike
  15. John H
    John H Senior Member
    2,208
    558
    An interesting note in the comments. Ford includes electric miles NOT powered by the plug in their 60%. :( Using this method, the regular Prius might achieve ~60% as well. Using the same method, the Volt fleet would be ~99%.
    The article's headline is also a bit misleading. Ford is reporting 60% of miles driven are electric, NOT that 60% of trips don't engage the gasoline engine.
  16. austingreen
    13,703
    4,229
    Austin, TX, USA
    IMHO milage percentage not trip percentage is a better measure, but.... These miles should not include miles recharged by the ice not the plug. I don't know if there is a way to determine this in the cars software, which makes it misleading.
  17. John H
    2,208
    558
    I agree but the trip percentage is useful, as well as the % days EV is useful. If we come to realize that 350 days out of 365 can be accomplished without using gasoline the demand for EVs will surge. 15 days a year can be covered with a ZipCar, the new Enterprise CarShare (Enterprise CarShare - Explore our Car Sharing Programs ), or trading with a neighbor or family member.
    JimPHL and 3PriusMike like this.
