Here is the comparative formulas for operating a PiP in all gas vs. all electric
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Vulcanman, Jul 27, 2013.
  1. g4_power
    g4_power Junior Member
    105
    I
    If PiP truly could get better mpg, I'm wondering if the lithium battery is more efficient than the NiMH
  2. Vulcanman
    Vulcanman Junior Member
    68
    It's lighter for one thing.
  3. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    The lithium battery is better all the way around... efficiency, discharging, and recharging. It is lighter with respect to density, but it is quite a bit larger (therefore heavier) than the NiMH pack in the regular Prius. You can actually see its ability to capture more energy from braking on the display, if you are lucky enough to be able to do a side-by-side comparison.
    g4_power likes this.
  4. g4_power
    105
    I
    It's only lighter in terms of energy density. The overall weight of the PiP battery is about 100 lbs heavier.
