Solar panel
Discussion in 'Gen 3 Prius Main Forum' started by MPGnutcase, Jul 31, 2013.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I wanted to start a page that shows the works of the solar roof, for those who have one you love it I know because I do...........
    Voltage is generated when the solar panel is exposed to sunlight the output wire maybe energized even after the vehicle is shut off and the 12 volt auxiliary battery is disconnected. Current will only flow if the solar ventilation blower fan circuit is turned on.
    Seymour5000 and p00kienrayray like this.
  2. MPGnutcase
    579
    114
    Chicago
    [​IMG]by using the solar panel it helps to keep the inside of the car from getting so hot you can't touch anything inside the car. Also you can hit the A/C button on your FOB to start running the A/C before you get to the car
  3. MPGnutcase
    579
    114
    Chicago
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    It is a great feature and changed the game. I read on PC that the air exhausts from the car by blowing over the traction battery thus improving the health of the battery.
    MPGnutcase likes this.
  5. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Thanks. This thread was much overdue. Too many questions on how the solar vent system works.
  6. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Actually you wouldn't want that 'Still kind of hot' interior air blowing through the HV battery.
    Example, my car/battery is at 68° after sitting overnight, the battery is slightly warmer by the time I get to work from the commute.
    But as the car sits in the sun all day, that interior air is still much hotter than outside air as it exits the car through the cabin exhaust vents, as seen in the diagram above.
    You would not want that hot air passing through the HV battery heating it up above where it was in the morning.
    It will be warmer than in the morning but hopefully not as hot as the interior air. And some of the air may be passing through the HV battery anyway, but it's a much more restrictive path.
    I love this option !! I wish the Volt I'm replacing it with had such a feature....
  7. JMD
    3,779
    1,282
    If you leave it on all time the interior temp never gets that hot
  8. MPGnutcase
    579
    114
    Chicago
    It is not perfect but it does help the dash plastic really gets HOT in summer so this system just keeps it from hitting super high temps
  9. JMD
    3,779
    1,282
    I read it reduces mold and odor in the AC system
    Bill Norton likes this.
  10. Seymour5000
    Seymour5000 Junior Member
    Kentucky
    IMO it gives the Prius a sporty look. I vouch for the functionality in KY Summer. Great thread!
    JMD likes this.
  11. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I get that you like the looks of the mirrored solar panel on the roof, but looks can be deceiving. Carry extra weight on the roof of a car is not what I would call "sporty."
  12. MPGnutcase
    579
    114
    Chicago
    It does way more but I am getting 57-58mpg around town
  13. Seymour5000
    Kentucky
    Key words: looks sporty. ;)
  14. MPGnutcase
    579
    114
    Chicago
    yes it does
    Seymour5000 likes this.
  15. Tideland Prius
    16,601
    Every time I get into the 2005 Prius, it's stinkin' hot (and it has the "Bisque" interior, which is beige in Toyota speak, though it does have a black dashboard). It's much cooler in the 2010 even with the "Dark Grey" interior. I rarely use the Remote A/C since the SPVS works well enough and the range on the fob is quite short. When I do use it, it's usually at work since I can activate it from upstairs and then walk down to the car.
