Let's talk tire pressure...
Discussion in 'Gen 3 Prius Main Forum' started by socal13, Aug 2, 2013.
  1. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    What kind of tires do you have and what pressure are you currently using? I have 17" Toyo Proxes with 40 fr/39 r. I was at a Toyota dealer yesterday and the salesman (says he was a tech) says to use the recommended pressure inside the door (33f/32r for my tires.) Any thoughts? Would like to hear other opinions. Thanks.
  2. tach18k
    tach18k Member
    406
    SoCal Beach Area
    I know many sales/tech guys that I had to walk them through my repairs, just saying...
    Rupert B Puppenstein likes this.
  3. socal13
    267
    Altadena CA
    I know what you mean... One sales guy didn't know what a Persona was.
    I know psi is a balance between tire wear life, comfort, handling, fuel economy, safety. I think the posted tire pressure on the door is way too low from what I have read.
  4. ETC(SS)
    7,304
    If you were that worried about fuel efficiency, you'd be rolling 15s, so I think I'd club up to the low 40's and see if that changes things for you in terms of FE versus ride. I use 42/40, but I prefer a stiffer ride that most.
    I'd recommend against going above the max sidewall pressure embossed on the side of the tire for all the obvious reasons and besides.....even if your tires are stiff enough for you to run over a dime and be able to tell whether it's heads or tails, that's not going to buy you much in the way additional fuel efficiency.
    Oh yeah.
    If you're one of those people who roll on nitrogenated tires...PLEASE at least consider replacing the lime-green valve stem caps with black ones.
    I drive a Prius too, and I hate to see people perpetuating poor stereotypes..... Just sayin' :)
  5. bisco
    52,264
    wouldn't be kosher for them to tell you anything but sop.;)
  6. g4_power
    g4_power Junior Member
    105
    I
    I always go by what's on the tires. My tires indicate 44 psi max, so I have mine at 40 psi which is about 10% below the max.
  7. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I'm running 38/37 on my Toyo's. I was thinking about going up to 40/39, but was a little concerned. Anyone running higher than 38/37 on Toyo's?
    Oh, yeah... Don't listen to the sales/tech guy. He's probably the same one that tried to discourage me from changing my transaxle oil!
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The Toyota dealer has to walk the company line. If he were to say something other than Toyota recommended, then he would be liable for any damages. It's like asking a mom if they she has a good kid. There's only answer to that question.
    TheEnglishman likes this.
  9. socal13
    267
    Altadena CA
    I'm running 40/39 on my Toyos... hoping this is a good balance between tire life and mpg.
  10. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    I'd imagine if the recommendation is 32/33, there's a reason they came to those numbers ?
    My car came with nitro fill, first thing. Did was to replace the green caps.
  11. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    I run 37 all around for mine
  12. bisco
    52,264
    factory spec is a balance of many things like mpg's, handling, noise, traction, longevity, etc. it's a recommendation, not written in stone, just inscribed in metal on the pillar.:cool:
  13. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    185/65/15 Kumho KH30 EcoWing tires on a 6.5 inch aftermarket wheel. I run 42 in all 4.
    I ran 42 in the stock tires too. The wider the tire, the more you'll get center wear at higher pressures.
  14. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    i was running 42/40 on my stock 15 bridgestone ecopio ep20 , but they were too harsh, so I dropped down to 40/38 and it is much better, with probably no noticable loss of mpg.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    42 front 40 rear
    jaymac likes this.
  16. boppo
    boppo Active Member
    799
    139
    Owego, NY
  17. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    42/40 is my sweet spot too.
  18. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I am using Michelin Primacy MXM4 215/45-17, 40 psi front and rear. The Michelin "Owner's Manual" that comes with the tires says to use the manufacturer's recommended pressure as a minimum and the maximum load pressure on the sidewall as a maximum. That gives plenty of range to find pressures that suit your driving style and road conditions.
    There is no one best set of pressures that work for everyone in all conditions, it's something you need to find on your own through experimentation.
  19. mmmodem
    2,732
    1,703
    Bay Area, CA
    In general, higher PSI tires mean better fuel economy, louder tires, and less comfortable ride. Not always but in general. Some of us prefer comfort and some of us prefer economy. Toyota recommends a balance of the two. Safety-wise, it's clearly printed on the Ecopia EP20 tires that came with my car can handle a max of 44 PSI.
  20. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Does anyone run a side to side bias to compensate for side to side weight distribution differences?
