Just bought 2011, but only 1 key
Discussion in 'Gen 3 Prius Main Forum' started by Ktnws, Jul 14, 2013.
  1. Ktnws
    Ktnws Junior Member
    San Diego, Ca
    I am terrified I will lose, so want to get another ASAP! I am sure the keys are ridiculously expensive, hoping not over $300 does anyone know how much and can I only get at dealership?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ebay, programmed by the dealer.
  3. Mayoub
    Mayoub New Member
    Detroit, Michigan
    I would not go to the dealer. I had same situation with a 2012 rav 4. I bought the transponder key for 39.95 from eBay. And locksmith programmed for $40.
    Make sure you get transponder key that corresponds with your year make and model. Good luck.
  4. bisco
    51,895
    get it done before you lose it, or it gets really expensive.
  5. g4_power
    g4_power Junior Member
    105
    I
    Locksmith at the dealership ?
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    In general you might just be wasting you money in trying to get a ebay sourced key to work. The keys are designed to only pair with one car. Do more research on PriusChat since some people have claimed that SOME locksmiths (with the right software) have managed to reprogram used keys.
    It is advisable to get a second key since the dealer will have major problems if you loose the ONLY key. It might cost $1000 to tow you car and get a new key in that case.
  7. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I would go to yhe dealer where you got the car and get one at COST
