Gas savings
Discussion in 'Gen 3 Prius Main Forum' started by MPGnutcase, Aug 5, 2013.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    So today I was at Kmart Pharmacy and when you get a prescription filled you get a coupon for
    BP gas with a discount of 10 cents a gallon with a max of 20 gallons. Also I use my Costco card and get 4% back on gas [was 5% in the old days]
    What do you do for your gas discounts?
  2. g4_power
    g4_power Junior Member
    105
    I
    Some grocery chains also sell gas. They reward their frequent shoppers with points which could be used for gas discounts.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    In north Virginia we use Giant foods (grocery) discount for Shell.
    Which reminds me I have to fill up today w/ 50-cents off/gallon.
    Safeway chain gives the discount for Exxon.
  4. terry brecheen
    139
    30
    houston, texas
    I use Kroger"s food store here in Houston. When you accumulate a 100 points equals 100 dollars spent you get 10 cents a gallon off at Shell gas stations. Works for me.
  5. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Our local Price Chopper and Sunoco do this but with 9 gallon fillups, saving 10 or 20 cents a gallon really doesn't make a lot of difference.
  6. Seymour5000
    Seymour5000 Junior Member
    Kentucky
    I shop at Kroger. They have a rewards card program that gives discounts for fuel every $100.00 spent per month. The fuel reward can be used at Kroger gas pumps or $0.10 off per gallon at Shell. We choose Shell for fill ups. I'm paying about $30.00 per fill up every two weeks on 89 Plus grade. I've always used 89 Plus in my other rides. I've had my Prius for a month now and am using 89 Plus - do y'all think it matters?
  7. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    If you use 87 instead of 89 you will get better mpg. higher octane burns 3% faster and no extra power is gained. (That is my understanding). You certainly are wasting some money by using higher octane than necessary. 85 octane works fine in mountainous areas and is many times available. At sea level 89 octane may be called for. The lower the terrain, the more octane you should use (denser air).
    Seymour5000 likes this.
  8. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Many people got a prius to save money on gas. 10-20 cents a gallons saving is part of the equation, I would think.
