JDM Prius Steering Wheel
Discussion in 'Gen 3 Prius Accessories and Modifications' started by w202mae, May 18, 2011.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    I simply tightened it until tight, but some people like to play it safe and torqued it to 37 foot pounds. Not too concerned as it's not like it'll come loose if the nut were to fall off as the steering wheel is held on by splines.
  2. larryt1026
    larryt1026 Junior Member
    61
    may be a dumb question...but lefty loosey on that centet bolt? I'm struggling to even loosening itolus wheel also turns while you try to loosen that center bolt...any advice? I don't want to break anything lol. I'm turning it counterclockwise as hard as I can. nothing
  3. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Doesn't matter as you've already marked the center line. Yes, it's held on tight. Pull on the end of the ratchet and use your body for added leverage.
  4. larryt1026
    61
    finally got lol. now comes the actual hard part of yanking the steering wheel. I'm actually taking a break right now from it lol. pulled as hard as I can a couple of times already. no luck
  5. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    I had to yank on it repeatedly for like one minute before it'd pop out, but I didn't use a wheel puller.
  6. larryt1026
    61
    I just got my steering wheel out. Pulled as hard as I can and all of a sudden I'm flying backwards. Now I am just waiting for my friend to bring me a torque wrench. But he won't be off for another 2.5 hours. I'm thinking about just tightening it without one...
    Btw...does it worry no one that the old steering wheel was so hard to pull off...but the new one just slides right on?
    Also, I broke a tab on the steering wheel controls. The long cylindrical one that goes into one of the holes. Might have to buy a new set.
    Thanks for all your help!
  7. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    That's normal.
  8. larryt1026
    61
    one last question..how do you know when you have the new steering wheel all the way in? I pushed as hard as I can to install it..is that good enough? There is a good gap between the back steering wheel cover and this part attached: PhotoMay1935911PM.jpg
  9. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    The wheel turns against that part so it can't be flush and a gap is normal or it'll rub.
  10. larryt1026
    61
    ok so installed! thanks for all your help 32kcolors. only thing I am worried about is that the steering wheel is not on all the way down the shaft. It probably has 1/2 cm gap and I ended up torquing it at 33 pounds. What do you'll think? ok? thanks!
  11. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Take a pic and we'll be able to tell.
  12. larryt1026
    61
    here we go. thanks!
  13. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Yep, normal.
  14. lensovet
    2,614
    495
    Burlington, NJ
    so how anyone tried getting the heated steering wheel? and figuring out how to wire it up so that the heating actually works?
  15. Aerolite
    Aerolite Junior Member
    55
    CA
    Looks fantastic!
  16. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Tap, tap, tap... bump, bump, bump.... not just a straight pull,:
    Whether it be the wrench handle or the back of the wheel (which the Japanese call a handle :).... a firm tap, tap, tap or a bump, bump, bump... the nut will pop loose, the wheel will pop off....
  17. larryt1026
    61
    whats a tap and a bump? lol
  18. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Prius-wise, with the socket on the nut that holds on the wheel (not the nut that holds onto the wheel), sharp taps with the ball peen hammer on the end of the socket handle....
    When the nut's off, then with the palms of the hands, sharp bumps on alternate sides of the back of the wheel, trying to knock the wheel back, up toward your nose :)
    Worked for me.
    (Otherwise, 60s terminology... you will have to google Carol Doda... North Beach... and the like :)
  19. g-gas
    g-gas New Member
    2013 Prius v wagon
    a couple of questions
    1) will this steering wheel void the warranty of the car.
    2) will it fit on a 2013 prius v (lowercase v for the Prius v, NOT an uppercase v) 2.
    3) is anyone willing to install this on my 2013 prius v (again, lowercae v for the Prius v) 2. willing to pay for your time. sounds like a job less than an hour apparently. will take you out to lunch too.
    im in the LA area. close to redondo beach.
  20. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    My dealer, somewhat distant from L.A., didn't bat an eye at the push-button JDM shifter, nor the JDM steering wheel.
    You can check part numbers... but I'd be surprised if it did not fit (small comfort...).
    There are several pictorials on here for D-I-Y... bit of a commute for me, but I'm sure someone will volunteer for compensatory lunch, Prius chatting, etc. :)
