Traction Control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by longshot, Aug 5, 2013.
  1. longshot
    longshot Junior Member
    83
    2013 Prius is there any way to disable the traction control. Trying the push start button 2 times and push gas pedal 2 times etc. method wont work on this year.
  2. Bill Norton
    Bill Norton Senior Member
    2,211
    745
    MONW, Ks.
    2019 Prius
    L Eco
    Do a search for Test Mode. It's just a chicken dance on the pedals and switches.
    It's for emission testing on a dyno.
    No cruise control, a big pop up blocking the display, no stability control.
    But if you hate your tires and want to have fun, go for it!! I use it all the time at the auto-crosses!! (Not really)
    It goes to normal at power cycle.
    longshot likes this.
  3. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    And another thing. The Gen II Priuses did have troubles on snow and ice where it didn't take much for them to get stuck. You'd be in semi-deep snow; the wheel would start to skid as you'd try to get out of there; the traction control would turn off power to the wheels; the wheels wouldn't spin. Tow truck time and Very Irritating.
    On Gen III Pruises the software appears to have been tweaked. One can skiz the tires a bit, although not as much as our motocross friend above would like. I, personally, haven't felt like I've been close to getting stuck, ever, since getting the 2010 I'm using, and that includes dashing around in 4-5" of snow while training my daughter on how to do skids. (Not much luck, the car works hard to prevent skidding around.) YMMV and all that.
    KBeck
  4. longshot
    83
    Just tested this on my 2013 Prius 2 and the traction control light stayed on and on the screen said "Maintenance mode"
    These steps must be completed within 60 seconds.
    To disable traction control on the prius:
    1) Turn the car to ignition by pressing START twice without pressing the brake.
    2) Floor the gas pedal two times (two full top to bottom pressings)
    3) Make sure the parking brake is on, and while pressing the brake pedal put the car into NEUTRAL(How to put it in Neutral IG on/RDY off, just depress and hold brakepedal, then move shifter to N for a couple of seconds). The park will disengage and on the screen it tells you.
    4) Again press the gas pedal two times
    5) Push PARK and press the gas pedal two more times
    6) Now put your foot on the BRAKE and press START one time while holding the brake down.
    Also set your emergency brake before you start this procedure. :)
    SPH-L710 ? 2
  5. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Thank you, longshot.
    I have two further questions...
    - To resume normal operation mode all we have to do is switch off the car, and then star over as prompt?
    - What do you mean "set your emergency brake"...?
  6. Mendel Leisk
    41,861
    Isn't it also possible to break something in this test mode? Forget what, maybe over-revving something in the transaxle. Bottom line, it's not intended as a normal driving mode.
  7. longshot
    83
    Set your emergency brake just to be on the safe side. Yes once u shut off the car and restart it goes back to norm.
    cm_tenderloin ?
