USB connector
Discussion in 'Gen 3 Prius Main Forum' started by WildOne, Aug 5, 2013.
  1. WildOne
    WildOne Junior Member
    29
    Note: Originally posted in wrong forum (Prius v). Reposting in right forum.
    Compared to my old HCH II, the new Prius is making me scared.
    Old vehicle (2009 Honda Civic Hybrid):
    New vehicle (2013 Prius Four):
    Problem is, I'm afraid I'll break the cloth-like plastic tab connecting it because the connector is a pop-out unlike the old one. I seem to use so much force on the tab that I'm afraid I'll break it. :(
    It seems to take so much force to release it compared to the old vehicle that I use too much force. :(
    Any advice?
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    The one thing that really gripes me about my Prius is the placement of the USB port in the center console. I don't know what the %#•* the designers were smoking when they came up with that idea. Hey! Let's remove all the stuff out of the console so we can plug in the iPod.
  3. WildOne
    29
    They moved it from the glove box because it had no hole to pass the cable through.
    At least with the center console it easily closes over the cable without causing it to snag.
    That and the glove box is a hot spot where you're not supposed to store electronics like iPods etc.
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    To each his own. I prefer the location for the USB plug because I can hide my iPod in there. I cram a lot of stuff in my center console as well but the other end of the cord that goes in my ipod is easily accessible.
    There's really no difference in breakage from what I can see on the Civic versus the Prius. Maybe the Prius would be sticking out a little more precarious. I use a USB extender cable so I don't have put the actual plug go under stress of repeatedly being plugged in.
  5. Prius NZ
    Prius NZ Junior Member
    70
    27
    Auckland, New Zealand
    If find once I plug the usb cable into the connector it is extremely hard to pull it out. The connector module is only held in with spring clips and these fail and the whole unit pops out exposing the internal wires. Anyone else had this or is it back to the dealer?
  6. BZzap!
    1,607
    878
    The center console is so far to the back that you have to plug in the USB connector using the Braille method. The center console and USB placement is altogether, a bad design.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    OP, please report the thread next time and we will move it. By creating a second thread you leave the other one lying there unless someone else reports it or a mod, like just happened, stumbles upon the error. Thanks :)
  8. ST321
    ST321 Junior Member
    39
    Vegas
    I picked up this item:
    right angle USB extender
    and it solved my issues nicely. Now I easily plug and unplug things into the end of it, and since it's a right angle plug, it sticks out less than plugging my USB flash drive directly into the port. It's much easier to plug in various things.
    By the way, I tried plugging in a USB hub, and it didn't come up on my screen as separate devices.
    Prius NZ likes this.
  9. DomoDriver
    DomoDriver Junior Member
    28
    New Mexico
    Why don't you just leave the cable plugged in to the car? That's what I do. We've accumulated so many of these cables over the years, we have extras anyway.
    Nora likes this.
  10. S Srivastav
    S Srivastav New Member
    Am I reading this right? Is the USB/Aux module is only held in with spring clips? Can it be popped out with a screwdriver? Do the wires come off the connector or are they soldered? Can I buy a replacement module, and if so, where?
    Lots of questions :) I have a broken USB stick jammed in my USB port and efforts to take it out have partially damaged the connector.
    BTW - mine is not a Prius V. I have a Prius 2011.
  11. saul
    saul Junior Member
    30
    miami beach
  12. saul
    saul Junior Member
    30
    miami beach
    i dont use the iPod i use pandora from my i phone with blue tooth
  13. Prius NZ
    70
    27
    I bought a cable to leave permanently in the USB socket and that has solved the problem. Oddly it has no trouble being plugged and unplugged; it was just the Apple brand connector that got stuck. The cable has several options so works with my iPhone5 and my partners iPhone 4 :rolleyes: cable.jpg
  14. Prius NZ
    70
    27
    Yes it is just held in with spring clips. Sounds like it is not Toyota's finest piece of design. You would need to order one from your dealer as they probably are custom made for the car.
