Cruise Control
Discussion in 'Gen 3 Prius Fuel Economy' started by WildOne, Aug 10, 2013.
  1. WildOne
    WildOne Junior Member
    29
    I've heard that cruise control reduces mileage. This was in relation the Honda Civic Hybrid (Gen II).
    I read this from a tips thread on GreenHybrid.
    I know that the Honda hybrids start the ICE first and then the electric motor, while Toyota hybrids do the opposite. Is this true?
    Does this also apply to the Prius?
  2. 510bg
    510bg Member
    142
    I drive a 90 mile commute mainly on cruise control 65-75 mph 50-60mpg. Most of which is flat road. Sure I'd like to get more mpg but I'm happy with the results.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    There's not a single answer for all situations and drivers. For many drivers it may save fuel in some situations, cost fuel in others and make no difference some of the time. Certainly, a blanket statement that CC costs fuel is wrong.
    spiderman likes this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Cruise Control neither anticipates hills nor knows how long they are, so it does not speed up just before a hill, nor going downhill. It does not slow down right at the crest. All of which can help MPG.
    In my case, I can drive (North South) 156 miles whilst only gaining (or losing) 100 feet of elevation, so hills are not a major concern and Cruise Control serves me well. (The highest point in MS is 880 feet, but it is not near me
    You did not post a location (which will ALWAYS hamper our ability to advise you on any subject) so I have no clue how hilly your normal driving is.
  5. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    It would be interesting to see a real world test on just how much difference this makes. Aside from irritating other drivers, I wonder if the difference needs to accumulate over a pretty long drive to be meaningful. Anyhow, I get excellent mileage just leaving the CC to handle things. I will say that RACC is a fuel waster, since it's constantly adjusting speed in traffic - but its OK on the open road.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    it all depends on the situation...
  7. Mendel Leisk
    41,433
    I'm coming from a second gen Civic Hybrid and I'd concur: with that car the cruise seemed to have a negative impact.
    I've found the 3rd gen Prius Cruise Control quite effective at keeping the mpg numbers high, at least as showing on Scan Gauge. Most anytime I activate it I'll see the numbers improve.
    In cruise the car will aggressively stay in stealth mode. It'll also regen going down steeper grades, to maintain the set speed.
    I use it quite a bit, any time traffic is light, at various speeds/conditions. Basically any time I may need to brake fast or negotiate a curve I for sure disengage it, but other than that...
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) My 9.8 mile daily work commute is about 7.5 miles interstate. I use cruise control 100% of that portion. All level ground and I wouldn't anticipate any real MPG loss. There's also a almost daily speed trap. Cruise control once set is effortless. Having the radar cruise control is a big plus.
  9. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    My experience is that cruise control always lowers mileage. Finding the stealth mode is a moving target and CC does not understand it anyway. That being said, the advantages on a long trip, for me, outweigh the mileage loss.
    510bg likes this.
  10. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I drive 105 miles a day over very hilly terrain. I use cruise control any time I am able to because I have found it is much better than me at regulating the amount of acceleration/deceleration needed to maintain a fairly consistent speed up and down hill. I have also found that my mpg goes up when I maintain a consistent speed. I generally have it set at between 62 and 69 mph and attain between 54 and 60 mpg (on the display) when I use CC.
    510bg likes this.
  11. bisco
    51,907
    cruise will maintain a fairly consistant speed on hills, which is why it costs mpg's. i find when i'm in cruise many others keep passing me and then slowing down. it's a pain in heavier traffic when i keep catching up to people.
  12. bwilson4web
    16,205
    I used cruise control and shifting between "N" and "D"+'resume' to do this:
    An incredibly boring 'stunt' in my wife's 2010 thanks to cruse control.
    BTW the cruise control light in our 2003 Prius burned out earlier this year.
    jgilliam1955 likes this.
  13. El Dobro
    El Dobro A Member
    7,088
    3,270
    I use CC as much as possible. In my case, one speeding ticket offsets any fuel savings. :D
    bwilson4web and JimboPalmer like this.
  14. jodamiller
    jodamiller Junior Member
    Eau Claire
    On flat ground, I find that cruise control does a better job of keeping the engine near the stealth mode/eco level threshold than I can. That being said, I've very proactive in coasting into stops and turns and then manually accelerating back to cruising speed before reengaging the CC. I've only had my Prius for three months, but I have a higher MPG rating after every fill up so far and using CC when best has worked out well.
  15. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    The average speed of 22 mph may have something to do with this.
  16. bwilson4web
    16,205
    Actually the minimum cruise control speed is 23 mph but it is unusable. The first dip in speed and it kicks out. So during the drive I was using 26-27 mph as the cruise control set speed. But even in a well planned route, there are stop lights, stop signs, and when I arrive at work, a parking lot. The average 22 mph is accurate because it does include stops and parking lots.
  17. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Tell us more, Bob! So you cruise at 26-27 mph, but what are the conditions that lead you to N? Do you resume from a stop or after getting back to speed? What is CC doing here that is different from your manual control?
  18. bwilson4web
    16,205
    The marathon drive was a 'stunt' and not something I recommend to anyone. I took pains to choose routes where I would not be blocking traffic and times when there was little or no traffic around. But during the stunt:
    • Set cruise control to 26-27 mph and monitor energy flow display . . . drive the car
    • When energy flow shows arrows from wheel to battery, shift into "N" -> the car will roll faster on downgrade
    • When car speed approaches 26-27 mph in "N", shift into "D" and hit "resume" on cruise control -> car will continue at set speed
    • When braking, shift into "D"
    That is it,
    ps. The physics behind it:
    1. Cruise control speed -> minimizes aerodynamic drag; eases burden on operator and, efficiently moves car forward or ascending upgrades.
    2. Shift "N" -> the car's potential energy is converted by the downgrade into kinetic energy, the most efficient transfer possible.
    3. 26-27 mph -> provides enough margin to handle upgrades. With practice, 25 mph is possible but 24 mph is nearly impossible and 23 mph is not possible.
