GPS icon question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Aug 11, 2013.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    Does anyone know what the little moving dot is on the bottom of the GPS icon? Image.jpg
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:Not sure, "North up"?
  3. mikenancy1
    105
    Geneva, IL
    Probably not, as I was driving northeast at the time. Logical guess, though!
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Per the manual, Current Vehicle Position mark. Indicates the current position of the vehicle and it's directional heading.
  5. markabele
    5,084
    1,782
    Nebraska
    Thanks, but unfortunately that doesn't answer his question.
  6. mikenancy1
    105
    Geneva, IL
    It's not the arrow I'm looking at, but the little dot below it. When you're watching the dot, it's constantly moving. It looks like a busy little gnat! I only noticed it after my son pointed it out to me. It's barely apparent.
  7. El Dobro
    El Dobro A Member
    7,088
    3,270
    Great, now I have to go out to the car and look.
  8. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Probably GPS coordinates which always pops around. The software on GPS devices is what snaps you to the road.
    iPad ? HD
    lensovet likes this.
  9. El Dobro
    El Dobro A Member
    7,088
    3,270
  10. lensovet
    2,615
    496
    Burlington, NJ
    this is correct. you can see this perfectly when you veer off-course – the little blue dot will actually follow your location, while the circle+arrow will continue driving correctly because it doesn't recalculate instantly.
    at the same time, i'm not sure why they kept it there.
  11. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused: Aren't "current position" and "directional heading" two different things? The latter, being the busy little gnat. Makes sense to me.
  12. lensovet
    2,615
    496
    Burlington, NJ
    Actually, the former is the gnat, and it's the raw position, rather than the snapped-to-road/current-route position.
  13. bisco
    52,186
    i've never even noticed it.(n)
  14. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    It signifies your actual current position....watch it when you leave an offramp, the ARROW takes a couple seconds to "catch up" to the dot. The dot is the actual GPS coordinate, while the arrow must FOLLOW THE MAP SOFTWARE on the roads. The dot does not follow the road at all, it can go anywhere.
    actually it is odd the TOY left the dot showing.
    Dan
  15. mikenancy1
    105
    Geneva, IL
    Makes sense now. Thanks@
  16. Vulcanman
    Vulcanman Junior Member
    68
    If you stare at the tiny blue dot long enough while driving ... the only direction you will surely be heading is UP.
  17. markabele
    5,084
    1,782
    Nebraska
    Hopefully...
