buzzing sound with ac on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kevine64, Aug 15, 2013.
  1. Kevine64
    Kevine64 Junior Member
    87
    Normal to have a buzzing so7nd from the car while parked with the ac on? Its not terribly loud but can be heard inside the car with windows up.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the appropriate sub forum
  3. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    Yep, perfectly normal.
  4. Kevine64
    87
    Is it also normal to feel a light thunk when the ice kicks in??
    Im new to the hybrid cars and want to catch everything before my certified warranty ends lol.
  5. bisco
    52,292
    i don't know if either are normal, but mine does both!:p
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    If something major goes wrong, it'll let you know right away.
  7. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    It ain't right, but it is normal :p
  8. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    How loud is the buzzing? Loud enough that maybe it's a leaf or something caught in the system (had that a few times on an 80s Volvo)?
    Yeah, car air conditioners are fountains of odd little noises.
  9. bisco
    52,292
    seems more like an electrical noise, i only notice it at a stop with ice off and hardly noticeable unless window is open.
  10. Kevine64
    87
    Yea. Same here. Sounds more electrical. And its not too loud but can hear it with windows up. Can hear it very very well outside the car.
    I also hear a light squealing when breaking. Hoping thats normal too....
  11. bisco
    52,292
    braking at any speed? forward and reverse? push hard on the pedal or gentle?
  12. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    It's the multi-speed electric air conditioning compressor.
    Run the AC, step outside the car when the engine is not running and you can hear it plainly.
    I have the remote AC button on my key fob.
    I hear it start and change speeds as I approach the car.
    It ain't right, but it is normal.
    Someday this will not be so noisy....
    The real light squeal noise is the inverter turning regen-braking forces into HV DC current to charge the battery.
    This will be muffled someday on future generations.
  13. Kevine64
    87
    Only hear it during light braking going forward. Probably normal but just wanted to make sure
  14. bisco
    52,292
    hard to say for sure, but probably regen activity. if you have time someday, go to a dealer and take a new one for a test drive. then you can hear for yourself what is 'normal'. there is also a section in the manual discussing hybrid sounds.
